Thread: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    Jan 2015
    United States
    called around and a magnaflow universal is gonna be $108 and then an old timer at an exhaust shop is gonna weld it in for me at $60... sucks not having my lift open! lol Oh well. It'll be easier this way and I like him and his work.
  2. #22 Re: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    You can get that cat for 50 on e bay.
  3. #23 Re: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    Jan 2015
    United States
    Yea for sure, but that doesnt solve the NOW issue. Oh well. It'll be worth it. Costing me more money fussing with it because I'm not working on other money making deals. But yes, I totally agree.
  4. #24 Re: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    Drill few holes in the cat. A buck twenty is a lot to toss out window.
  5. #25 Re: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    Jan 2015
    United States
    If I did drill 6-10 1/2" holes in it technically it would be 'unplugged' right and it should run better? right? good idea!
  6. #26 Re: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    it should. will sound like crap but will let the exhaust out.
  7. #27 Re: P0171 and P0300 Codes, Mildly Rough Idle, Rough on starts, Slightly Elevated Idle
    Jun 2021
    Rear o2 will match the front allot of the times of the motor is extremely lean or extremely rich.. try cleaning the maf and check for vacuum leaks. To eliminate a bad brake booster unplug it's vac line and plug it. If the car runs good after then replace the booster. You can also use the fuel trims to do a cyl balance test. You can also inject propane into the intake hose by the air filter and see if the fuel trims come down, if they do then it's a fuel problem or possibly vacuum leak.. inject the propane and see what happens, check for vacuum leaks and bad brake booster and do the cyl balance test.. you should be able to figure out the problem by doing those things. If it's a series 1 or 2 3800 there is a real good chance the Mass air flow sensor is bad. They are known for bad maf! But only replace with a acdelco maf! To many after market maf been bad out of the box.
    I know this is a old thread but I figured I would put some knowledge out there for anyone with those cars still
  1. Rough idle
    By Jonarin in forum 3.4L V6 (LQ1) DOHC
    Last Post: 10-22-2014, 05:57 AM
  2. 99 GTP Troubleshooting- rough idle, misfire? No codes (warning very NOOB)
    By Juxtaghost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:29 PM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. Rough idle when car starts?
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-19-2012, 01:18 PM
  5. Rough Idle
    By Red_GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2008, 02:29 PM
