Thread: Coolant elbow exploeded
Results 1 to 15 of 15
  1. #1 Coolant elbow exploeded
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I was on a full throttle merge, and the coolant elbow that sits right under the supercharger snout sort of exploded. I know they make a metal version but im having trouble finding it.
    Ebay shows an upper and lower elbow, which one is this? Does anyone know where i can find the aluminum version?
  2. #2 Re: Coolant elbow exploeded
    most parts stores carry it, its next to the plastic crap ones in the HELP section. dorman makes em.
  3. #3 Re: Coolant elbow exploeded
    Sep 2014
    Richmond Virginia
    would it be the upper or lower one?
  4. #4 Re: Coolant elbow exploeded
    they are sold as a pair, you change em both.
    you take the alt off, and then the alt bracket, both elbows are fitted to this bracket.
  5. #5 Re: Coolant elbow exploeded
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I've read that a little RTV on the O-Rings helps the metal ones seal better, might not hurt. Probably not necessary though, my metal ones were put on with motor oil as a lubricant and no RTV, and haven't leaked at all.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  6. #6 Re: Coolant elbow exploeded
    thats all i'd do, clean the holes real good, make sure theres no plastic elbow left in any of the holes, oil the O rings with motor oil, slide them all in.
    the how to. http://www.grandprixforums.net/threa...coolant+elbows
  7. #7 Re: Coolant elbow exploeded
    GTP Level Member Javi's Avatar
    OKC, Oklahoma
    Your local auto part store should have them.
    47065HP is the part number and yes add a small amount of RTV on the ends to help seal better.
  8. #8 Re: Coolant elbow exploeded
    Sep 2014
    Richmond Virginia
    I got it, going to put it on tomorrow night
    Thanks for the info!
  9. #9 Re: Coolant elbow exploeded
    SWPA
    Quote Originally Posted by Javi View Post
    Zero need for RTV. All I ever put on them is a little bit of coolant to lube them. My plastic ones never leaked for over two years and only got changed to aluminum because the plastic one blew.
  10. #10 Re: Coolant elbow exploeded
    Dec 2008
    Lawndale, CA
    Quote Originally Posted by GTP131 View Post
    Once I switched over to using the GM o-rings they seal much better than what comes with them.
  11. #11 Re: Coolant elbow exploeded
    Still don't understand why anyhow has trouble with an elbow sealing.
  12. #12 Re: Coolant elbow exploeded
    Nov 2011
    NY
    Elbow Sealing
    Probably because they've used RTV before and left a lip, leaving an uneven seating surface for the o-ring that eventually leaks, or failed to 'Clean Out' the holes properly, thereby achieving the same result. Lolz...
    Anyways, I agree, no extra sealing required, they work just fine as they're made, if plastic is used, then they should be changed out on regular maintenance interval, especially for the few $ they cost...
    Pre-lubing the rings with a little silicone or likewise will aid seating and keep rings in shape longer.
  13. #13 Re: Coolant elbow exploeded
    Oct 2011
    Toledo, OH
    Quote Originally Posted by coolone View Post
    As I replaced mine with aluminum ones on Friday following Bill's write-up, I have no leaks and used no RTV either. The upper engine side hole clearly had a ring of crap in it that a few seconds with some fine scotch-brite pad cleaned right up.
    Pre-lubing the rings are a must, and another reason for leaks is people do that wrong too. Can't just slap some grease on the outside and shove it in. Make sure the whole o-ring has a coating, twist it and roll it around to coat it fully before installing it.
    7"
  14. #14 Re: Coolant elbow exploeded
    Oct 2012
    philly
    Make sure elbows are inserted fully into the holes.
    Make sure you don't mix the bolts up during reassembly. Previous owner put the long bolt in the wrong spot on mine and it screwed right through the valve cover!
    Check power steering fluid while it's apart!!
  15. #15 Re: Coolant elbow exploeded
    IndustrialF.. I just lube the outside.. never rolling the rings.
    Vic.. if you fully insert the elbow..it won't be at 90 degrees and the plastic ones tend to distort shape then blow. Totally agree about the PS fluid.
  1. Bad coolant elbow
    By Shoggy24 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 06:11 PM
  2. Coolant elbow broke
    By Lil larry in forum General Tech Discussion
    Last Post: 05-14-2013, 05:53 AM
  3. Coolant Elbow...AGAIN!!!
    By armyrebel03 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-10-2011, 06:32 PM
  4. coolant elbow replacement
    By reaper6 in forum General Tech Discussion
    Last Post: 07-26-2011, 07:15 AM
  5. Coolant Elbow(s?) on 98 GTP
    By ASCStinger in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-03-2009, 03:46 PM
