Thread: Hards GTP now on 3.0 pulley
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #21 Re: Hards GTP now on 3.0 pulley
    heres the crystal ball of whats going to happen.....
    first dustin gives in listens plays with some different spark plugs.
    gets pissed still not happy
    finally switches to E85!
    /END
    lol you cant stop the inevitable.......
  2. #22 Re: Hards GTP now on 3.0 pulley
    Or just sprays it
  3. #23 Re: Hards GTP now on 3.0 pulley
    GT Level Member Hardonyomom's Avatar
    aurora
    Timing is at 15 degrees at WOT
    I'm not sure what my AFR is because i don't have a wideband. The car was originally tuned with a 3.2 but i relearned my trims driving around nice and easy then going wot after about 20 mins and my trims are good and i have 0 knock.
    I'm using ac delco iridium 41-104 plugs gapped to .48 right under .50
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  4. #24 Re: Hards GTP now on 3.0 pulley
    Yikes on the plugs
    Meh on the 15*
    I bet it's rich
  5. #25 Re: Hards GTP now on 3.0 pulley
    Antioch, IL
    I dont know how you can stand such slow acceleration, Im sitting in my chair rocking back and forth trying to make it go faster!
    2009 Challenger SRT8
    Expert at being gay.
  6. #26 Re: Hards GTP now on 3.0 pulley
    aurora
    Quote Originally Posted by ITHURTZ View Post
    I know what you mean but this isn't turboed either. I guess for supercharged its ok. Turbo would definitly be funner though.
  7. #27 Re: Hards GTP now on 3.0 pulley
    Funner.
    This was my 3.1" pulley, for reference.
    No intercooler/meth, pump gas, heads/cam, stock rockers, 42.5's.
    This was just getting it going, AFR was like 10.9~ LOL.
    http://vid241.photobucket.com/albums...-100Pull-1.mp4
  8. #28 Re: Hards GTP now on 3.0 pulley
    aurora
    Good news sorta !
    Turns out that the belt i was using was still too long. I had bought a few belts when i was doing my build and putting the 3.4 on. I was using a dayco 506090 belt which was fine for 3.4. I dropped down to a dayco 506085 which made 3.2 belt feel tighter and pull better. I then put that same belt on the 3.0 and that all was well. I wanted the 506080 belt which is the perfect size but they didnt have it so i took my chances. Well, today i went to just start my jeep and while my car was i was looking at my supercharger belt and it was flapping the side. I then put it back on and put it right in the middle, revved it for a sec and belt started to slide off to the side again but never came off. Went looking in garage and it turns out i had the 506080 belt that i NEED that i wasn't able to return cause i ordered it this spring from amazon lol. Looks like ill be putting it to use now
    SOoooooo MAYBE there is a chance that when i get the right size belt on i will be getting even more power. Who knows how much i was losing but kinda makes me excited to see what will happen now
  9. #29 Re: Hards GTP now on 3.0 pulley
    Donating Users timboku's Avatar
    Montgomery, IL
    So is there a chance you can beat a stock gxp now ..jj all good!
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  10. #30 Re: Hards GTP now on 3.0 pulley
    GT Level Member atj8's Avatar
    Midwest
    60 roll and ill race you! ^^ i was just about to remind him of that Timboku
    98 GTP Gen v 2.8,FSIC,xpcammed,SD headers,CAI,CORNFEED,TIMBOKU TUNED
    04 Comp-g Turbo,Cornfed, TIMBOKU tuned
  11. #31 Re: Hards GTP now on 3.0 pulley
    aurora
    Quote Originally Posted by timboku View Post
    I sure hope so!!!
  12. #32 Re: Hards GTP now on 3.0 pulley
    aurora
    Quote Originally Posted by atj8 View Post
    Well see what happens with your little ssic and I rarely drive over 55mph so well see lol
    On another note that belt was SUPER tight to get on I had to use silicone spray and a ton of patience. Now that I have correct belt its quite a bit louder and more responsive. Ill try to get a vid up
  13. #33 Re: Hards GTP now on 3.0 pulley
    dyno it then put it on e85 and dyno it and see what you can gain.
  14. #34 Re: Hards GTP now on 3.0 pulley
    Midwest
    Quote Originally Posted by Hardgainer View Post
    14lbs of boost on genv on corn vs oldman dustin..pretty sure i got you buddy. oh by the way what do you scan your car with? hows that torque app working for you?
  15. #35 Re: Hards GTP now on 3.0 pulley
    for the love of god boost number doesnt mean crap. its a pointless number that greatly depends on other factors......
    if your intercooled and running e85 why such a giant 3.4 pulley?
    im pretty certian a 3.2 would be doable on just e85.
    (could it be the intercoolers is doing nothing?) lol sorry we all know my view of them on a m90 car.......
  16. #36 Re: Hards GTP now on 3.0 pulley
    aurora
    Quote Originally Posted by 98FvckingCrazyVet View Post
    Well, he isn't on e85 YET. But when he does go Corn im sure he will get down to at least a 2.8. Torque app is working good for me abby
  17. #37 Re: Hards GTP now on 3.0 pulley
    i just like calling out peoples sig's and mod lists thats all............
  18. #38 Re: Hards GTP now on 3.0 pulley
    Midwest
    Actually dustin iam on e85. Ask the man that tuned my car.
  19. #39 Re: Hards GTP now on 3.0 pulley
    aurora
    how do you like it? Is it a big difference? I may need your help when i do mine. I need to know what to order and how much is involved.
  1. Modular SC pulley and hub, water pump aluminum pulley
    By MattStrike in forum Wanted To Buy - Parts
    Last Post: 03-12-2013, 08:03 PM
