Thread: 2002 GTP Injector issue
Results 1 to 8 of 8
  1. #1 2002 GTP Injector issue
    Dec 2014
    somewhere
    I have GTP vehicle I bought as a donor car for another vehicle that needs an engine. The engine turns over fine, the fuel pump comes on, but the injectors are not firing. What could be wrong here? I need to try and get this engine to run on its own so I can be sure it's not something like the crankshaft position sensor or something. Planning to go to Florida soon and need to have this project done ASAP with the much appreciated help of this forum.
    Yes I am a noob
  2. #2 Re: 2002 GTP Injector issue
    St. Louis
    Have you checked all the fuses (inside the car and under the hood)?
  3. #3 Re: 2002 GTP Injector issue
    Dec 2014
    somewhere
    where in the car are the other fuses? Under the seat like on my SSEi Bonneville?
  4. #4 Re: 2002 GTP Injector issue
    glove box and under the hood pass side fender. black box near the battery.
    use a test light in the injector plug see if it flashes when the key is turned to run or start. you'll need some one to turn the key for you. it will only flash a few times as the key is turned cause it being primed to start.
    or you can use a side marker light bulb out of the head light, pull the tabs out on the bulb and stick it in the injector plug, the bulb will flash if the injector is getting power.
  5. #5 Re: 2002 GTP Injector issue
    Dec 2014
    somewhere
    do you know what fuse number it is or is it labeled?
  6. #6 Re: 2002 GTP Injector issue
    theres a fuse map on the inside of the fuse box cover, pull and check every one if need be.
    you should also be looking for damaged wires.
    maybe some back story would help out too.
  7. #7 Re: 2002 GTP Injector issue
    Dec 2014
    somewhere
    This car IS wrecked so I am sure that could be a reason why the injectors aren't spraying.
  8. #8 Re: 2002 GTP Injector issue
    if its crashed in the front, yeah there could be bad wires now.
    if the engine ran before the wreck, rip it out and use it.
  1. 2002 Grand Prix Radio Issue
    By 00Bonnie in forum Audio, Security & Visual Electronics
    Last Post: 06-18-2014, 12:51 PM
  2. 2002 Speedometer Issue
    By reclark19 in forum Introductions/Noob Questions
    Last Post: 06-02-2014, 10:30 PM
  3. injector issue
    By gtpinsc in forum General Tech Discussion
    Last Post: 04-02-2011, 09:57 PM
  4. 2002 Grand Prix Starting Issue.
    By Honchop1 in forum General Tech Discussion
    Last Post: 11-10-2010, 08:35 PM
  5. 2002 GP GT 3.8 N/A Trans Issue
    By GRANDPRIXBANDIT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-14-2009, 09:03 AM
