Whats the easiest way to get the case needle bearings out. Getting the gen v ready for the powdercoaters
Gen 5 bearimg are open both sides. They go into a bore that is totally closed. Even if there was a cross drill the bearimg isn't closed.
You need an internal bearing puller and a slide hammer.
Ok cool cool. Now to look in my box n see if ive got a slide hammer pilot bearing removal tool
Are you sure is my question powdercoating ovens get over 400ยฐ if im not mistaken. Are we sure that it wont mess up the needle bearings. If this is so i will not mess with them
The grease and seal are not rated to 400.
I replace a set in a powder Coated blower, they needed done. The case was bead blasted but the grease wasn't right.
I dont know maybe i should replace em for good measures being that i got the blower from the jy
There probable fine tell you bake them to 350-390. If you don't bake them, clean them out and regrease them.
Well i got the needle bearings out. But i need to know if anyone knows who sells them or have a part number for them
Zzp or zzp on ebay
