3.4 should be pretty good. I ran a 3.4 and e85 on a pretty much stock motor a long time ago.
Im on a 3.2 and 42s. Works fine.
Never had a wideband on my dd car. Its 100% not needed on e85. Tuning cold start is not a real thing unless you have some mechanical issues. Mine has started fine and its so haggard and broken im surprised it runs at all.
lol ^^ he speaks the truth; however, I always like to have a wb and scanner to watch whats going on.
Cold start is a tuning issue with e85. Not only is the stoich diffrent but the evaporation factor of of ethanol is diffremt than gas, thus requiring tuning for colder weather areas.
Ive never been a fan of this plug and play e85 without tuning becaise theres more to be had out of your money with e85. Timing changes being the most important.
Well if it works then you dont need to tune it. You wont find many gains doing timing changes and you wojt find any gains doing fuel changes unless you are fixing a mechanical issue.
I emailed ZZP to see there recommendation before i started this and i just got a repsonse that "those injectors definitely wouldnt be big enough on e85" for the build i want (rockers Plog Downpipe, 3.2)
said a stock pulley is all i could run on the 42.5s?
This doesnt seem right... I have been told by zzp a few months ago that 42s on e85 support 280whp which is almost a 100 whp increase
PRJ ran 12.34 on 42s and e85. He wasn't on a stock pulley.
They should support at least 250whp on e85 according to a quick calculation. That is pretty conservative though. More than that shouldn't be a problem.
Unless this is going on a return less fuel system. Then yeah, they will he very close to maxed on a stock pulley.
This is my experience, (on 60# injectors)
Ran great down to a 3.2, anything smaller than that and you'll need to upgrade the fuel system.
OH.....and you can run 42's on E85 with no problems.![]()
Yeah you have a return system. Get a Casper's or racetronix rewire on there, and you'll support a lot of power.
just finished tonight having my l67 running v8supercar spec 107 octane e85,my mods are 12psi pulley,60lb injectors walbro 450lph pump with yt 1.9 rockers![]()
