Thread: can i run 3/8th inch radiator?
Results 1 to 8 of 8
  1. #1 can i run 3/8th inch radiator?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    My radiator in the GTP has a hole in it. I ordered a cheap replacement on ebay, unfortunately fedex damaged it so i am waiting for another one. I found out that they offer two sizes for the wbody platform a 1" and a 3/8ths inch core.
    the one i have coming to me is a 3/8. Is this going to cause any issues? I know it has less cooling capability, but is it diminished enough to cause a problem?
    I can get a 1" core locally for 105, but with tuition, christmas, and classes coming up, id rather not spend the money if i dont have to.
  2. #2 Re: can i run 3/8th inch radiator?
    Mar 2012
    NC
    You'll be fine.
  3. #3 Re: can i run 3/8th inch radiator?
    i think you mean 5/8 th's rad, not 3/8 th's they only sell 1 inch and 5/8 ths that i could find, im sc'ed and am running a 5/8 th's rad, it should be a 1 inch. but 5/8 was cheaper. temps run the same.
  4. #4 Re: can i run 3/8th inch radiator?
    Sep 2014
    Richmond Virginia
    looks like it is 5/8ths, the guide says it matches the cars with the one inch core so i might be getting that one maybe?
    i just want to make sure im not going to overheat if i get the "smaller" core
  5. #5 Re: can i run 3/8th inch radiator?
    Mar 2012
    NC
    I ran a 5/8" rad on my build no problem.
  6. #6 Re: can i run 3/8th inch radiator?
    it was sven who told me i could run a 5/8 rad with no issues, hes right. engine temps are the same.
  7. #7 Re: can i run 3/8th inch radiator?
    Sep 2014
    Richmond Virginia
    On another note what temp do the fans come on? I think the car has a 165* tstat on the move the engine temp stays at around 160-170, at a ligt it starts climbing i think its hit 180-190, haven't heard the fans engage yet.
  8. #8 Re: can i run 3/8th inch radiator?
    fans come on at 212.
    id get a warmer t stat. 180 or stock 195. if you have a 180 in there now, wont know till you take it out and look at it, put a stock one in.
  1. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  2. do i new a 3 inch dp
    By gpgt2002 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-14-2010, 11:45 PM
  3. flanging from 2.5 inch downpipe to 3 inch exhaust?
    By 2000GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-19-2009, 07:44 PM
  4. 20 inch rim help
    By mzendano in forum Tires & Wheels
    Last Post: 01-10-2009, 02:48 PM
