Thread: car only getting 15mpg. and a screeching noise from rear main/flywheel area
Results 1 to 20 of 20
  1. #1 Re: car only getting 15mpg. and a screeching noise from rear main/flywheel area
    Fix the pcv in the charger.
    There is an o-ring on the pcv, then a spring above it and a gasket on the cover.
  2. #2 Re: car only getting 15mpg. and a screeching noise from rear main/flywheel area
    GT Level Member 99GPGTP's Avatar
    Rome GA
    My pcv didn't have an o ring. There is a piece of plastic that the pcv sits on and and then the spring. And gasket and cover. I have eliminated the transmission by taking the torque converter bolts loose
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  3. #3 Re: car only getting 15mpg. and a screeching noise from rear main/flywheel area
    Mercer, Pa
    Quote Originally Posted by 99GPGTP View Post
    That is the problem, you need an O-ring. It seals the pcv so you don't leak full manifold vacuum to the crankcase all the time.
  1. Rear Main Seal Opinion
    By 50Coupe in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-25-2014, 10:24 PM
  2. Rubbing noise from rear passenger tire area.
    By PTGsDaytona500GTP in forum Brakes/Suspension/Chassis
    Last Post: 12-24-2013, 04:00 PM
  3. Screeching noise from motor after header install
    By nawarkk in forum General Tech Discussion
    Last Post: 07-21-2012, 07:35 PM
  4. Rear main seal
    By FX4 Level II in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-30-2012, 02:03 PM
  5. Rear Main Seal Plate
    By NHRA21 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2011, 05:49 PM
