Thread: zzp fuel rail ???
Results 1 to 3 of 3
  1. #1 zzp fuel rail ???
    Sep 2013
    Massachusetts north shore
    Hey guys i finally found a set of zzp modded fuel rails on ebay nib but after reciving them i noticed that the braided hose and fittings are small and look like a fuel restriction the stock pressure line is -6 or 3/8 and the return is -5 or 5/16 but the zzp hose looks smaller than -4 or 1/4 has anybody had a issue running out of fuel on the rear bank with the new rail i am probably going to run a new AN6 hose under the snout in the near future but i am a little nervous i am getting close to needing injectors and before installing them i was wondering if anyone had any input
  2. #2 Re: zzp fuel rail ???
    Sep 2013
    If i do upgrade the hose to AN6 what type of AN hose is best for fuel e10 mostly
  3. #3 Re: zzp fuel rail ???
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Friend is running the zzp modded rail on his 330 whp e85 car... I'm sure it flows plenty.
    04 GTP -HAI, 1.9 rockers.
  1. Modded fuel rail leaking( should i get fuel logs??? )
    By Hardonyomom in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2014, 05:38 AM
  2. The retainer/clip the secures the fuel line to the fuel rail.
    By Sudden in forum Wanted To Buy - Parts
    Last Post: 06-22-2013, 05:20 PM
  3. Fuel line leak at fuel rail
    By Burbman in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-25-2013, 12:43 PM
