Thread: Why so rich?
Results 1 to 12 of 12
  1. #1 Why so rich?
    Oct 2014
    Pennsylvania
    So I installed speed daddy headers, 3.5 pulley, short ram intake, and tr6 plugs.
    At WOT my AFR is high 10s low 11s.
    Why is it so rich?? I'm also still getting KR of a max 7 degrees but usually 2-4. I have not tuned it yet and I think I have some rotor rattle.
    The knock seems to come on just after the shift.
    https://vimeo.com/112134652
  2. #2 Re: Why so rich?
    Dec 2010
    DMV
    You need a tune and drop back to the 3.8. 7* degrees can't be good on a 3.5 pulley
  3. #3 Re: Why so rich?
    Stock AFR on 97-00 cars normally runs right around 11, maybe a tad lower.
    Perhaps the o2 sensor is rubbing the tunnel, a known cause for random kr.
  4. #4 Re: Why so rich?
    Oct 2014
    Pennsylvania
    I'll be swapping in a gen v blower this winter.
    I don't see 7* all the time so I'm guessing some if it is false knock.
    I'll look to see if the O2 sensor is leaving any marks like it hits.
    I'm going to lean out the fuel a little to get my AFR to a more reasonable level. Also keeping an eye on knock when I do.
  5. #5 Re: Why so rich?
    Jul 2012
    Chicago
    Does it spike randomly to 7*? If I were you, I'd put the 3.8 on for the time being. The colder temps are not helping you.
    -Carl
  6. #6 Re: Why so rich?
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    high 10s low 11s is fine for WOT AFR. I would not touch your AFR until you figure your knock out... 7* is BAD news. especially on anything smaller than a stock pulley.
    If you have more than 0* KR i would not drop pulley unless you wanna swap your motor...
    04 GTP -HAI, 1.9 rockers.
  7. #7 Re: Why so rich?
    False.. meaning, something that you need to fix is causing it? LOL
  8. #8 Re: Why so rich?
    Feb 2009
    flintnasty MI
    Why does everyone think they have been cursed with the .01% chance of getting false knock lol.
  9. #9 Re: Why so rich?
    Oct 2014
    Pennsylvania
    Yes the 7* was one time and it was a spike. All my knock are spikes. Nothing is constant.
    When I do a 3rd gear only pull I get either zero or 2* knock. I suspect it's false because I have some sort of noise that could be rotor rattle. It disappears when the belts are off.
  10. #10 Re: Why so rich?
    GT Level Member 99GPGTP's Avatar
    Rome GA
    Take belt off supercharger and turn sc pulley by hand in small amounts back and forth and see if you feel any play in the coupler. If there is play just replace coupler
    99gtp 3.4"on ported m90, zzp 1.0 pcm, speeddaddy headers, stock mufflers w/cat and res delete,104's,FWI,180* stat, exhaust ported heads,Dog bones flipped, 18" 350z wheels
  11. #11 Re: Why so rich?
    Oct 2014
    Pennsylvania
    There is no back and forth play but there is some noise when I spin it.
  12. #12 Re: Why so rich?
    Removing the belt is a good idea.
    Also; read fuel trims themselves.
    LTFT's are an easy way to tell whats going on as well.
  1. To rich?
    By Timing in forum PCM Tuning
    Last Post: 09-02-2014, 05:27 PM
  2. Car is running rich... I think
    By ElAlacran2010 in forum General Tech Discussion
    Last Post: 02-25-2011, 08:51 AM
  3. ok what is going on???? lean or rich?
    By jj7ski in forum General Tech Discussion
    Last Post: 01-06-2011, 10:11 PM
  4. Running rich
    By saleenprix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2010, 08:53 AM
  5. Rich Condition HELP!
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2009, 04:51 PM
