Thread: Pulling the engine and/or trans
Results 1 to 20 of 25
  1. #1 Pulling the engine and/or trans
    SE Level Member ScreaminZ's Avatar
    Feb 2014
    United States
    A few questions:
    1. Can the trans be pulled out from the bottom WITHOUT dropping the subframe?
    2. Can the engine and trans be pulled out from the top as one unit?
    I would rather pull the engine and trans out together from the top. The trans is going to need a rebuild so I might as well pull the engine too because there are a few things I want to do to it. If not I can just pull the engine first and then the trans if they can't come out together as one, but I just wanted to know. Thanks
    97 GTP stock
  2. #2 Re: Pulling the engine and/or trans
    Enfield, CT
    If you learn to search, you would easily find answers to those questions
  3. #3 Re: Pulling the engine and/or trans
    Feb 2014
    United States
    Quote Originally Posted by HighOctaneRacing View Post
    Oh how original. Funny, I remember when I used to say that to newbies on a different forum for a different car. After a while I would just answer their questions instead of being a jerk.
    I have seen this: http://www.gpona.com/forums/transmis...al-t27215.html
    But I have also seen this: http://www.ehow.com/how_5403486_repl...rand-prix.html
    Hence my confusion for the first question.
    And for the second question, really all I need is a yes or no answer.
    97 GTP stock
  4. #4 Re: Pulling the engine and/or trans
    Enfield, CT
    Quote Originally Posted by ScreaminZ View Post
    That's right, I am being a "jerk". This question has been asked many times in the past few weeks and people keep making new threads over it when there is already a solid write-up for it. Myabe if you weren't such a JERK, you would read this when you first signed up. http://www.grandprixforums.net/threa...elpful-Threads
  5. #5 Re: Pulling the engine and/or trans
    Feb 2014
    United States
    Sorry, I was cranky yesterday and it spilled over into my internet life
    97 GTP stock
  6. #6 Re: Pulling the engine and/or trans
    both can come out as one out the top, you'll need to get the master cylinder off and out of the way.
  7. #7 Re: Pulling the engine and/or trans
    Feb 2014
    United States
    Thank you
    97 GTP stock
  8. #8 Re: Pulling the engine and/or trans
    one is for each, one is a engine removal, the other is a tranny removal.
    you can also drop the sub frame and lift the car up over the whole engine, tranny and sub frame.
  9. #9 Re: Pulling the engine and/or trans
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    I prefer both out the top..whether your doing tranny or motor work. its simple and can be done in 2hours.
  10. #10 Re: Pulling the engine and/or trans
    GT Level Member Tea Time's Avatar
    New Brunswick
    I've dropped the driverside of the sub frame to replace the tranny, tried to cheat....it works, but imo, its far easier to just pull the combo out the top. i didn't have to remove the master cylinder either... or the hood for that matter. cherry picker and a leveler (or just ratchet straps lol) are worth their weight in gold.
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  11. #11 Re: Pulling the engine and/or trans
    Feb 2014
    Milwaukee
    I rebuilt my trans with it still in the car. Just took the side cover off and lowerd the subframe a bit
  12. #12 Re: Pulling the engine and/or trans
    Allow me to help. I've done a few write ups and all can be found by searching on "ea sy" without the space and my user name.
    Here's engine only
    http://www.grandprixforums.net/threa...highlight=easy
    Here's trans out the bottom (does require cradle pull, will not screw up alignment)
    Here's trans and engine out the top
  13. #13 Re: Pulling the engine and/or trans
    Feb 2014
    United States
    Here's engine only
    Thanks BillBoost, I found your and browsed through your write-ups a few days ago actually. I found them to be very good. I just was not a fan of having to drop the subframe, even though its not a big deal. I've done it before with my camaro but I was hoping to get away from having to do that with this car.
    My dad and I swapped transmissions in his 99 voyager last year and we didn't have to drop the subframe so I was surprised that these cars needed it
    I will pull the engine and trans from the top since I want to do some things to the engine anyway (like a leaking rear valve cover etc.)
    97 GTP stock
  14. #14 Re: Pulling the engine and/or trans
    W bodies gotta drop it..
    92-99 H bodies..the cradle would come apart and it was super easy.
  15. #15 Re: Pulling the engine and/or trans
    Feb 2014
    United States
    Yeah from now on I'm going to stay away from FWD autos haha. But I love these L67s I can't decide!
    97 GTP stock
  16. #16 Re: Pulling the engine and/or trans
    Tell Kyle to eff off... he likes swearing for the point of it. Plus.. it's funny as hell to see him riled.
  17. #17 Re: Pulling the engine and/or trans
    Feb 2014
    United States
    LOL
    97 GTP stock
  18. #18 Re: Pulling the engine and/or trans
    May 2012
    Where winter never ends
    ignore me......
    2000 Regal - Winter Beater
  19. #19 Re: Pulling the engine and/or trans
    He totally got pissed at a radiator cap one day and whipped it across a street into a corn field.
  20. #20 Re: Pulling the engine and/or trans
    Enfield, CT
    Lol. That's what happens when you lost all motivation to work on a GP or in your words "Giant Pile"
  1. Trans Connector/trans swap... Pulling side cover? 01 GT
    By MrPhotographer06 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-27-2013, 01:34 AM
  2. Anyone replaced a flexplate without dropping cradle or pulling engine?
    By Damnir in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2013, 11:32 AM
  3. pulling trans out of 01 grand prix gt
    By adamtrippin in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-18-2010, 11:11 PM
  4. pulling engine forward...
    By Jakegday in forum General Tech Discussion
    Last Post: 01-15-2010, 08:02 PM
  5. Pulling my engine
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-26-2009, 01:07 PM
