A few questions:
1. Can the trans be pulled out from the bottom WITHOUT dropping the subframe?
2. Can the engine and trans be pulled out from the top as one unit?
I would rather pull the engine and trans out together from the top. The trans is going to need a rebuild so I might as well pull the engine too because there are a few things I want to do to it. If not I can just pull the engine first and then the trans if they can't come out together as one, but I just wanted to know. Thanks
