Thread: *CHEAP* Fuel Pump Rewire/Hotwire ??
Results 1 to 20 of 20
  1. #1 *CHEAP* Fuel Pump Rewire/Hotwire ??
    SE Level Member TehGTP's Avatar
    May 2008
    Saint Louis, MO
    ive been browsing around checking on some prices for the infamous "fuel pump rewire/hotwire"
    i ran accross this and was wondering if anyone used this, it looks like an AWSOME deal and seems to be the racetronix/casper style ??
    FULL THROTTLE SPEED - Item Description Page
    if the link doesent work, its basicaly the same thing labeled for a Fbody in the fuel upgrade sections.
    my question being, is this the same thing ?
    2007 Corvette Z06 - BFD Cam / E85 / milled & fixed heads
    2006 GTO M6 18's - SOLD - VRX5 Cam | FAST 102 | Exhaust
    2001 GTP - SOLD - 1.9 | TOG's | E85 | LC1 | B+G | AGX | GMPP | 3EP
  2. #2 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    May 2008
    Saint Louis, MO
    ok well i ordered it so we'll see how that goes.
  3. #3 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    GTP Level Member VinnieGTP's Avatar
    Las Cruces, NM
    If it was the LS1 rewire from full throttle its the same exact one the vendors sell for us, just cheaper. Full throttle is where one of the major ones gets all their fuel stuff from anyway.
  4. #4 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    May 2008
    Saint Louis, MO
    Thanks for the info.
  5. #5 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    GTP Level Member JoshMcMadMac's Avatar
    Waynesboro, PA
    I cannot tell if that has the right connector on it for our fuel pump. You really do not need a kit. You just need wire to run from the back of the car to the front, and tie it in place of the stock wiring.
    2000 NavyBlueMetallic GTP Coupe
    HPTuners / Intercooler / Devil's Own Meth / 1.8 SLP Rockers / 3.1-3.3" / 180° / TB Shield / FWI / PLOG / Jimmy-C Downpipe / U-Bend Delete / Mark VIII Fan / Alt. rewire / FP rewire / F-Body Brakes / Buick Strut Braces / SLP Tips / 20% Tint
  6. #6 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    I just picked up a wideband gauge from them earlier this week, great customer service.
    harness looks about the same...
  7. #7 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    Germantown, Maryland
    Quote Originally Posted by JoshMcMadMac View Post
    im not so good with electronics, but my father is. What kind of wire should I get and where should I purchase from? I'd like to start making my own rewires for everything on my car. I just need to learn how.
    Also will this bypass my fuel pump resistor??? Thanks
  8. #8 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Waynesboro, PA
    Quote Originally Posted by Quicklynx View Post
    All you need for the fuel pump rewire is wire, and a way to connect both ends. I recommend using a soldering iron to do it the "best" way. As for everything else on the car, you will probably get into the realm of a lot of relays. Also not difficult, once you get the concept of them down.
  9. #9 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    How can I bypass my fuel pump resistor???
  10. #10 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    SE Level Member 98SilvermistGTP's Avatar
    Nov 2008
    Eastern KY
    The casper kit I have came with a fuel pump resister bypass. It is a connector that just has a piece of wire that loops around on one side, and the other side connects to where you unhook the connector that goes to the resistor.
  11. #11 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    Does the ZZP rewire bypass the resistor? $80 for a pump rewire seems steep, but I may have to eat it. I'm pretty sure I have a bad resistor right now so I'm going to have to do something soon about it.
  12. #12 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    May 2008
    Saint Louis, MO
    well if you want to post in a thread that address' the price/quality issues why dont u at least click the link i provided for a GREAT deal.
    by the way, i did purchase it and install it, and it is completely plug and play and of the highest quality. did i mention super easy?
    /thread
    if you want to make one yourself just follow the instructions given.
  13. #13 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    the link you provided is broken... but I'll try and figure it out
  14. #14 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    http://www.fullthrottlespeed.com/itemdesc.asp?CartId={7AEEVEREST393C1-D2D8-49DD-BF03-266E2C459C89}&ic=717LS1HOTWIRE&eq=&Tp=
  15. #15 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    is that the one you ordered?
  16. #16 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    May 2008
    Saint Louis, MO
    thats the one.
  17. #17 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Waynesboro, PA
    You bypass the resistor simple, and free. You bend pin 85 on the fuel pump relay. I will check to see if I can find the picture of it.
  18. #18 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Waynesboro, PA
    Found it:
  19. #19 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    awesome, thanks!
  20. #20 Re: *CHEAP* Fuel Pump Rewire/Hotwire ??
    Jul 2008
    ok I ordered the part! Thanks!
  1. Fuel issue...possible fuel pump????HELP
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2013, 11:50 PM
  2. Is there a way to run the fuel pump
    By SyntheticShield in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-25-2008, 06:09 PM
  3. Bad Fuel Pump
    By JJ91284 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-17-2008, 11:52 PM
  4. Hotwire the Fuel Pump
    By TommyGloves in forum General Tech Discussion
    Last Post: 08-11-2008, 09:19 PM
  5. fuel pump or FPR? or both?
    By Toasty in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-07-2008, 03:43 PM
