Thread: replaced Radiator, have high idle when in gear
Results 1 to 3 of 3
  1. #1 replaced Radiator, have high idle when in gear
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I replaced my radiator and the new one seems to have done the trick. I noticed on the test drive that the car was idling around 1500 rpm when moving (in neutral) and 1100 when stopped.
    This seems unusually high to me. I pulled the battery out and im wondering if its just the relearn. when its still for more than 15 seconds it goes down to 900 (still seems a little high)
    Is there anything i could have disconnected that would cause this?
  2. #2 Re: replaced Radiator, have high idle when in gear
    sounds like a vac leak. see if your hvac controls still work, some cars have a vac line that runs across the rad support, maybe it broke.
  3. #3 Re: replaced Radiator, have high idle when in gear
    Sep 2014
    Richmond Virginia
    I drove it a good hundred miles today, and it seemed to be back to normal, other than the thermostat acting its a**.
  1. Replaced Thermostat in 3.1L now idles high around 3000rpm in park or neutral
    By ShevanelTakeTwo in forum General Tech Discussion
    Last Post: 01-19-2014, 11:47 PM
  2. High idle in every gear
    By shart in forum General Tech Discussion
    Last Post: 10-20-2011, 07:46 AM
  3. Alt. Died. I replaced, Now my idle is wierd.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2009, 09:22 AM
  4. High / Fast Idle - Idle Air Control motor?
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-30-2009, 11:28 AM
  5. For those who replaced 4th gear MPG increase?
    By a10tion in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-27-2009, 02:29 PM
