Thread: Boost psi... whats you guys psi on which size pulley
Results 1 to 20 of 31
  1. #1 Boost psi... whats you guys psi on which size pulley
    Banned
    Jan 2013
    maryland
    Just curious to see what how much boost you guys are seeing on pulley sizes I'm currently at 11 psi on a 3.0 pulley.. what's you guys boost looking like?
  2. #2 Re: Boost psi... whats you guys psi on which size pulley
    10 psi at 5600 rpm. on a 3.4 1.95 rocker, header set up.
    thats via the dash boost gauge, as well as dhp scans.
  3. #3 Re: Boost psi... whats you guys psi on which size pulley
    16psi on 2.8......
    Boost psi is JUST A NUMBER, the better the car flows the lower the number.
    So your car on a 2.8 wont make the same as mine on stock heads.
    Boost psi doesn't mean jack. Means even less if your comparing one engine to another.
  4. #4 Re: Boost psi... whats you guys psi on which size pulley
    GTP Level Member danomite02's Avatar
    Jul 2011
    CT
    3.4 pulley with 22psi
    and a T70 turbo :P
  5. #5 Re: Boost psi... whats you guys psi on which size pulley
    Does that car even run? last I heard it didn't.
  6. #6 Re: Boost psi... whats you guys psi on which size pulley
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    12-13 psi on a 3.5 on a gen v. with full headers.
  7. #7 Re: Boost psi... whats you guys psi on which size pulley
    Jul 2011
    CT
    lol when did you hear that Vet?
  8. #8 Re: Boost psi... whats you guys psi on which size pulley
    GT Level Member WolvesSoulZ's Avatar
    Québec
    Around 10-11 psi on 3.5 gen v, xp cam/plogdp combo.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  9. #9 Re: Boost psi... whats you guys psi on which size pulley
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by 98NoBallzVet View Post
    16psi on 2.8......
    Yeah just curious on a 2.8 I will probably be on 12psi since Im on stg 3 heads cam
  10. #10 Re: Boost psi... whats you guys psi on which size pulley
    May 2008
    Schuyler, NE
    I had 15 psi on a stock pulley gen v, l26, xpz, ported heads. Oh, at about 4k rpms.
  11. #11 Re: Boost psi... whats you guys psi on which size pulley
    Aug 2013
    Kitimat, B.C.
    11 psi on a gen v and 3.3 with cai and speed daddy headers.
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  12. #12 Re: Boost psi... whats you guys psi on which size pulley
    Mar 2012
    NC
    L36 block, ported heads, XP cam, SLP headers, Gen V, 3.4 pulley, IC'ed....sat at 6 psi. 8 PSI on a 3.2. 10 PSI on the 3.0.
  13. #13 Re: Boost psi... whats you guys psi on which size pulley
    Kemmerer, Wyoming
    full size phenolic intercooler, ported gen 3, 75 mm N*, gen 3 rotor pack with gen 5 coating, headers, and max out at 10 lbs of boost. also have a built transmission with a 2500 stall, not sure if that makes a difference.
  14. #14 Re: Boost psi... whats you guys psi on which size pulley
    Quote Originally Posted by danomite02 View Post
    last i remember the bottom end or cam was out? i dont remember its been a while.
  15. #15 Re: Boost psi... whats you guys psi on which size pulley
    Banned
    Jan 2013
    maryland
    [QUOTE=WolvesSoulZ;1289181]Around 10-11 psi on 3.5 gen v, xp cam/plogdp combo.[/QUOTE
    Why no headers? That's a interesting setup with that cam do plog/dp flows just as good as headers?
  16. #16 Re: Boost psi... whats you guys psi on which size pulley
    Mar 2012
    NC
    [QUOTE=jayroca;1289233]
    Quote Originally Posted by WolvesSoulZ View Post
    No.
  17. #17 Re: Boost psi... whats you guys psi on which size pulley
    Dec 2010
    DMV
    Peak at 12 psi with 3.4 setup with the plog downpipe combo
  18. #18 Re: Boost psi... whats you guys psi on which size pulley
    Banned
    Jan 2013
    maryland
    [QUOTE=Sven The Sexman;1289234][QUOTE=jayroca;1289233]
    No.[/QUOTE
    Lol well obviously plog dp is easier but for the easier install curious to see if it flows better which is probably not
  19. #19 Re: Boost psi... whats you guys psi on which size pulley
    Mar 2012
    NC
    It's better than manifolds...but not better than headers.
  20. #20 Re: Boost psi... whats you guys psi on which size pulley
    Oct 2011
    Puyallup WA
    3.3 gen5 xp plog ported rear 11psi
    08 G8 GT - exhaust Tune
  1. Whats going on guys
    By aph0213 in forum Introductions/Noob Questions
    Last Post: 01-13-2013, 06:52 PM
  2. Whats up guys
    By Mad GTP in forum Introductions/Noob Questions
    Last Post: 02-15-2012, 04:50 PM
  3. wbody store full-size intercooler with 42.5's = what size pulley?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 07:18 PM
  4. Pulley size vs. SC vs. boost
    By porshuh in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-29-2009, 07:12 PM
  5. Whats up guys?!
    By phat_ridegt in forum Introductions/Noob Questions
    Last Post: 01-21-2008, 02:24 PM
