Thread: Exhaust gasket leak; which parts do I need?
Results 1 to 5 of 5
  1. #1 Exhaust gasket leak; which parts do I need?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    So I'm chewing up coolant and it looks to be an exhaust leak. I have a fiend who'll be doing the work and I just wanted to check on the parts that I'll be needing;
    1) Exhaust manifold gasket set
    2) Lower intake manifold gasket set
    I am used to there being both upper and lower intake gaskets but there doesn't seem to be an upper available? Is it because of the Supercharger?
    Are there any other parts I should grab for replacement?
    Thanks guys.
  2. #2 Re: Exhaust gasket leak; which parts do I need?
    Coolant elbows too. And buy extra oil for another oil change, it's a very good idea to change the oil after a 10-15 minutes of running the motor to get any coolant out, if any fell inside the engine during the LIM removal.
    They make a supercharger gasket, it is called a upper intake gasket in some parts stores. Some parts store counter people are too stupid to figue it out. If you have a GEN 3 blower (97-03) it's like 10 bucks.
  3. #3 Re: Exhaust gasket leak; which parts do I need?
    I have also found it called an upper plenum gasket.
    Search on the Common Parts thread by me and you'll have the part numbers at your fingertips.
  4. #4 Re: Exhaust gasket leak; which parts do I need?
    Sep 2014
    St. Paul, MN
    Thanks guys.
    So
    1) Elbows
    2) Plenum/supercharger gasket
    3) Lower intake manifold gasket set
    4) Exhaust gasket
    Anything else?
  5. #5 Re: Exhaust gasket leak; which parts do I need?
    buy new vac lines and T's good chance they will brake when fiddled with during the lim job.
    advance has the best t's i could find. small white t's. 2 for two bucks. vac line is a buck a foot.
    makes sure your getting the metal lower intake gaskets too. some thread sealant for the lim bolts too.
  1. oil pan gasket leak
    By Mike3 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-01-2013, 09:12 AM
  2. Vac Leak... Bad S/C gasket?
    By al2000gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2012, 08:24 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
