Thread: should i advance cam 2 degrees
Results 1 to 10 of 10
  1. #1 should i advance cam 2 degrees
    GT Level Member jrb1027's Avatar
    Jun 2013
    brookville,IN
    Im in the process of getting engine put together with new heads and cam, the mechanic told me I may want to advance the cam a couple degrees with the timeing gears but wasnt sure, he said he would make some calls to find out, but i thought id ask on here first. He said he will degree the cam too.
  2. #2 Re: should i advance cam 2 degrees
    Many vendor cams have advanced timing in the grind. Since you don't say anything about what cam etc. Hopefully that info helps
  3. #3 Re: should i advance cam 2 degrees
    bill is right, here. most of them have built in advance.
    based on that the vast majority of us (read: all of us) degree it at zero when installing.
  4. #4 Re: should i advance cam 2 degrees
    bill is right, here
    You say that like I'm wrong more often than right? Go install your headers!
  5. #5 Re: should i advance cam 2 degrees
    Jun 2013
    brookville,IN
    Its an xp cam, he said he want the cam card too is this all the info thats on the cam card
    • 212°/224° at .050"
    • Intake Lift .325" (.520" lift at 1.6:1 rocker ratio)
    • Exhaust Lift .335" (.536" lift at 1.6:1 rocker ratio)
    • 116 Lobe Separation
  6. #6 Re: should i advance cam 2 degrees
    May 2008
    Schuyler, NE
    This is an XP cam card. Most people usually install them straight up. You will probably need to be more aggressive with the car than I'm assuming you are, to see a gain from advancing/retarding it.
  7. #7 Re: should i advance cam 2 degrees
    Jun 2013
    brookville,IN
    Thx, alot...what do you mean "You will probably need to be more aggressive with the car than I'm assuming you are"
  8. #8 Re: should i advance cam 2 degrees
    May 2008
    Schuyler, NE
    I'm talking about running race fuel, timing and pulley optimized. Basically, tuning it yourself for the very next run at the track.
  9. #9 Re: should i advance cam 2 degrees
    Jun 2013
    brookville,IN
    gotcha well full build is xp, intercooler, heads,headers,e85,2.8 but i want it steetable so ill just tell him to install it at 0
  10. #10 Re: should i advance cam 2 degrees
    Banned
    CT
    The XP cam has 2* advance built into it.
  1. Do NOT buy a coolant temp sensor from advance. Reads almost 45 Degrees higher.
    By PowerHouseCamaro in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-26-2013, 01:15 AM
  2. How many degrees of KR do you get?
    By slimguns in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-30-2013, 11:58 PM
  3. My new oil cap is 90 degrees out. :(
    By Kilroy in forum Visual/Body Modifications
    Last Post: 03-28-2013, 07:09 AM
  4. Suddenly getting 10 degrees of KR
    By buickman104 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-12-2012, 10:36 PM
  5. Ihave 4 degrees of kr
    By ryangtp89 in forum General Tech Discussion
    Last Post: 03-16-2008, 12:34 PM
