Thread: Hi pressure low pressure fuel connectors , i lost the springs that go inside. help
Results 1 to 9 of 9
  1. #1 Re: Hi pressure low pressure fuel connectors , i lost the springs that go inside. hel
    Enfield, CT
    Quote Originally Posted by hardgainer View Post
    stfu if your not going to be of any help, then don't say anything. Am i supposed to read your mind? All you said is tabs look like they are pulled far. Good solution!!!
    lmfao!!!!
  2. #2 Re: Hi pressure low pressure fuel connectors , i lost the springs that go inside. hel
    GT Level Member Hardonyomom's Avatar
    aurora
    Again, thanks for the help. So am i even missing any hardware or do i just need to bend the tabs back up? The low pressure line doesnt even have a tab but still feels like it wants to grab more.
    I found this thread and thought it was interesting on this topic
    http://rivperformance.editboard.com/...connector-leak
    F body Front, GXP rear brakes, SSC, Poly Dogbones, SLP Gen 1 spoiler, Gpo's, GTX hood, SD Air dam, LED tails, badges and decals, Comp G Seats,
    FSIC, Ported and painted Gen 3, ZZP LIM, SD Headers, REmoddified ZZP fuel rail, 60 lb injectors, LS7 lifters, 1.9 modded rockers, 2.6 pulley E85, 21 degrees timing -Timboku tuned
  3. #3 Re: Hi pressure low pressure fuel connectors , i lost the springs that go inside. hel
    aurora
    okay so i went to gm and they said i need new lines obv. So i went to napa and got some 3/8 fuel disconnect clips and one of them went in on the line that is on the right (high pressure one i think) The one on the left seemed like it was a tad bit smaller and wouldnt fit the circumference of the clip inside it. Hmmm what to do???
  4. #4 Re: Hi pressure low pressure fuel connectors , i lost the springs that go inside. hel
    aurora
    Thanks to everyone that helped out with this issue. The fuel feed is 3/8 and the return is 5/16. You can get the GM part 800-005 for 3/8 retaining clip or 800-006 for 5/16 retaining clip. So glad its figured out now.
  1. Replies: 19
    Last Post: 10-20-2015, 09:22 PM
  2. Lost Pressure
    By Mr D in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-30-2014, 03:12 PM
  3. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  4. lost my oil pressure
    By jjmac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2010, 12:16 AM
