Thread: Crank no start!
Results 1 to 2 of 2
  1. #1 Crank no start!
    SE Level Member RobGTP's Avatar
    Jul 2010
    Massachusetts
    Started my car after work ran for about 2 seconds then died. then would no restart or even kick (like disabled ignition) i can hear the fuel pump and smell fuel i have to assume it has an injector pulse but i will check tomorrow when its light outside, hooked up a scan tool and there is no rpm signal. Obviously Im thinking crank sensor but that usually cuts fuel and ignition so I'm a little confused. It has a zzp pcm in it and I'm not sure if that changed the fueling logic when it loses rpm signal or something, not sure, any suggestions?
  2. #2 Re: Crank no start!
    Florida
    Sounds very similar to a bad crank position sensor, ZZP PCM shouldn't have anything to do with it.
    Check all your grounds first (fast and simple)
  1. No crank no start 04 CompG HELP!!
    By 98ctd in forum General Tech Discussion
    Last Post: 04-13-2014, 07:52 PM
  2. Crank but no start.. Help!
    By GTP89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 11:31 PM
  3. Crank but not start
    By Coldwaves in forum General Tech Discussion
    Last Post: 05-20-2013, 05:21 AM
  4. Crank, but no start
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 11:28 PM
  5. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
