Thread: P0171 and running rough
Results 1 to 3 of 3
  1. #1 P0171 and running rough
    Aug 2014
    Sacramento
    Hey guys, not sure if this is the right spot to be posting, its only my second post on here.
    So lately I have been having some issues with my car, it really idles like crap. Drives fine until on the freeway and cruising at 2000 rpm, the rpms start bouncing, I speed up and that goes away.
    Yesterday I got a P0171 code that popped up for about an hour of driving, the code came out of no where, and disapeared.
    Here is the data from the P0171
    One thing that I have noticed is that my cars idle gets a hell of a lot better if I throw it in neutral or in park. It also runs better with the AC on.
    It almost sounds like my engine is tapping the frame. Could this be a motor mount gone bad? I really not sure whats going on over here.
    Here is what I have done in the last seven months, most very recent.
    MAF Sensor (threw code, replaced) 7mos.
    LIM Gaskets 7 mos.
    IAC (very dirty, replaced) 7mos.
    New Plugs 1mo.
    Wires 1mo.
    Coil Packs 6mos.
    Temp Sensor 2 weeks
    Sorry for the lack of info here, most of the time I have no idea whats going on.
    2000 GTP Supercharged, no mods. 199,000 miles on it.
    Thanks in advance for any advice!
    P0171 and running rough Attached Images
  2. #2 Re: P0171 and running rough
    Your fuel trims are maxxed out at +16.4 and thats where the P0171 code comes from, you have a pretty bad vacuum leak somewhere.
    If you can do a smoke test on the vacuum lines/intake to see where a leak is. And check all vacuum hoses for cracks and so on.
  3. #3 Re: P0171 and running rough
    Aug 2014
    Sacramento
    Awesome! Thanks for the suggestions. I don't have a smoke tester, is there an alternate way of doing this with like a cigarette or something? Also, I took a can of carb cleaner and sprayed it around all the hoses and the intake, no change in idle.
    I did have my brother do the gaskets for me, when I had them done, do you think that he could have done them wrong or is this possibly a head gasket issue? I'm not loosing any coolant and there is no oil the water.
    The code is gone and has not come back, but the car still has a rough idle and shakes pretty bad at start up for about 5-10 seconds.
    Thanks again!
  1. 05 GTP running rough (sometimes)
    By gwog in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2012, 02:01 PM
  2. Running Rough
    By Kenny75k in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2011, 02:02 PM
  3. running rough
    By BOOSTED GP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2011, 11:58 AM
  4. GTP Running Rough.. few new parts but still not running right.. HELP
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-29-2010, 02:34 PM
  5. 01 GTP running rough
    By tazgtp in forum General Tech Discussion
    Last Post: 03-28-2010, 04:10 PM
