Thread: Lightweight rotor pack
Results 21 to 40 of 42
  1. #1 Re: Lightweight rotor pack
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    Quote Originally Posted by 98ChainStretcher View Post
    sooooooooo if this works can I get a 2 inch pulley on my gen5 lol!!!
    LOL good luck on the machining for that. Maybe the dude can drill the snout too? :P
    04 GTP -HAI, 1.9 rockers.
  2. #2 Re: Lightweight rotor pack
    Get a steig port too.
  3. #3 Re: Lightweight rotor pack
    Feb 2010
    TN
    Once you drill holes in anything you weaken it and make it prone to stress cracks
  4. #4 Re: Lightweight rotor pack
    Jan 2013
    Australia
    I'm running a lightweight rotor pack from MACE engineering here in Aus. I can't tell how much the lighter rotors themselves contribute to performance... but when I had them fitted to a brand new blower which was fully ported I gained 32hp up top and about 20 - 25 across the rest of tbhe rev range.
    And on the dyno sheet it looks like the limiter could have been raised a bit and got maybe another 5 - 10hp out of it.. I just think my tuner didnt want to spin the stock bottom end too high.
    So I do believe they help a bit. Once you make over 300rwhp every hp is hard to come by anyway
  5. #5 Re: Lightweight rotor pack
    Kemmerer, Wyoming
    Wow, that sounds pretty substantial. Not sure what tbhe means
  6. #6 Re: Lightweight rotor pack
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Think he was trying to type, "the"
    Just my guess though, unless he typed that on purpose =P
  7. #7 Re: Lightweight rotor pack
    Aug 2013
    Sandy, UT
    THROTTLE BODY HEAT EXCHANGER! lol jk. Pretty sure its a typo for "the"...
  8. #8 Re: Lightweight rotor pack
    Aug 2011
    Michigan
    ^ this guy ;P
  9. #9 Re: Lightweight rotor pack
    Kemmerer, Wyoming
    My brain has been malfunctioning a lot lately
  10. #10 Re: Lightweight rotor pack
    Mercer, Pa
    Any reduction in rotating mass will be a gain in HP. Not sure how reducing the mass makes the supercharger capable of way higher pressure or significantly higher HP.
    This is a guy who intercools supercharger snouts. Never understood that one very well, why do you want to add heat to your intercooler loop to cool down your bearings.
    I would save your money, it's snake oil.
  11. #11 Re: Lightweight rotor pack
    Feb 2010
    TN
    Also how will it effect balance?
  12. #12 Re: Lightweight rotor pack
    Jan 2013
    Australia
    I did a fair bit of reading on the topic a while back... came across a thread somewhere where some dude did testing stock vs. drilled out rotors. Cant remember if it was m90 rotors though.. but the principal would be the same I guess... anyway, the drilled lighter rotors showed less flex and vibration.
    Also, of the people I know here who are using the MACE Engineering lightweight rotor pack none of them have had any problems. One guy is using a 2.4" pulley and overdriven balancer and even the coating on his rotors is still flawless after a year or so... he's making 450rwhp with the m90 lol
    As for myself, ive been using the light weight rotors for a month now.. and no problems as of yet.. and i'm not expecting any dramas at all.
  13. #13 Re: Lightweight rotor pack
    Kemmerer, Wyoming
    If shipping wasn't so bad I would be willing try one of those rotor packs
  14. #14 Re: Lightweight rotor pack
    Jan 2013
    Australia
    can't imagine it being much more than a hundred bucks or so...
  15. #15 Re: Lightweight rotor pack
    Jan 2013
    Australia
    how much do they want for shipping?
  16. #16 Re: Lightweight rotor pack
    Kemmerer, Wyoming
    I'm not sure but international shipping is bad
  17. #17 Re: Lightweight rotor pack
    Jan 2013
    Australia
    But to make use of it you'd want to be running a pretty small pulley... on a 3.4" it probably won't make any noticable difference.
    The harder you spin the blower the more the HP savings add up exponentially.
    here in Aus we a2a cool our m90s, pulleys in the range of 2.4 - 2.55" are common
  18. #18 Re: Lightweight rotor pack
    Kemmerer, Wyoming
    That's probably about right, a rotor pack shipped here in the states would be about 30 at the most
  19. #19 Re: Lightweight rotor pack
    Kemmerer, Wyoming
    I'm running a 3.2 pulley and a full size intercooler
  20. #20 Re: Lightweight rotor pack
    Jan 2013
    Australia
    full size w2a IC should be able to drop to a 2.8"? Properly tuned of course...
  1. Gen v or gen v rotor pack
    By 00grandprixgtp in forum Wanted To Buy - Parts
    Last Post: 12-15-2013, 12:29 PM
  2. lightweight rotor pack...
    By mskram1 in forum General Tech Discussion
    Last Post: 03-02-2012, 02:51 PM
