Thread: lean code rough idle
Results 1 to 4 of 4
  1. #1 lean code rough idle
    Jul 2013
    adrian, mi
    98 gtp. 1.9s, 3.4 pulley, headers and 103s. Random hard start with a rough idle and p0171 lean code. Any help is greatly appreciated
  2. #2 Re: lean code rough idle
    check for a vac leak.
  3. #3 Re: lean code rough idle
    check the EGR to LIM tube for cracks at the ends, do not spray stuff at it.. pull it off and look through it at light. 90% of them are cracked. Check TB gaskets and all others with carb/tb cleaner.
  4. #4 Re: lean code rough idle
    Jul 2013
    adrian, mi
    Thanks for the quick response guys. Will check it out this evening and let you guys know.
  1. Getting a lean code
    By 1999black3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2013, 01:40 PM
  2. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  3. Getting the idle lean again
    By Sandman in forum PCM Tuning
    Last Post: 04-15-2012, 10:57 PM
  4. lean at idle
    By JayGTP02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-30-2010, 02:24 PM
  5. lean condition code
    By TDCRacing in forum PCM Tuning
    Last Post: 05-06-2008, 07:12 PM
