Thread: Anyone (recently) bought and installed SD headers?
Results 1 to 20 of 24
  1. #1 Anyone (recently) bought and installed SD headers?
    Sep 2014
    Puyallup, WA
    Doing a search, they seemed sketchy on when they were bought if the headers were decent or not. Seemed at some point they switched to a SSAC copy and the headers were crap.
    Anyone bought and installed them recently care to comment? Don't want to waste the $240 to purchase garbage
  2. #2 Re: Anyone (recently) bought and installed SD headers?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Lots of people here use SD headers, they require some extra effort to get them to fit without hitting anything like massaging the firewall so the 02 doesn't hit against it but its not too hateful that and the flex can go bad but it seems to be a hit or a miss. Another con is they have this ubend/pipetrap in the downpipe, not really a restriction but it hangs kinda low.
    Not my pictures but shows what i mean.
    Also if you order them from SDs website its 217 shipped.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  3. #3 Re: Anyone (recently) bought and installed SD headers?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    i bought a used pair and IMO they're completely worth it. A lot of people here use them
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  4. #4 Re: Anyone (recently) bought and installed SD headers?
    Sep 2014
    Puyallup, WA
    Cool thanks for the quick replies. Going to order a set here in a few. Hopefully they aren't a huge ***** to put in... starting to get cold out!
  5. #5 Re: Anyone (recently) bought and installed SD headers?
    Mar 2014
    Tucson
    I bought and installed mine about 4 weeks ago. I was actually kinda surprised by the quality considering the price. The firewall/footwell clearance was the hardest part. About a half hour of pounding with a large ball peen hammer got be this:
    I also had to trim some length from the front header collector, and the rear of the crossover. About a half inch from each. Some will say you don't need them, but I highly recommend using band clamps. I ordered mine from Jegs. FWIW, the "Jegs" brand were actually stamped "Torctite."
  6. #6 Re: Anyone (recently) bought and installed SD headers?
    i also installed a set not to long ago.
    getting the stock crap off is more work then getting the headers on is.
    my o2 was hitting the fire wall good so i plugged the hole and moved the o2 to the cross over pipe. if you have this done, put the rear header in, then the pipe in, put a x where you want the o2 in the clear. no need for a o2 extention if you move the o2.
  7. #7 Re: Anyone (recently) bought and installed SD headers?
    Apr 2012
    Dayton, OH
    If you don't want to mess with pounding the firewall for 02 clearance you can have an 02 bung welded in the crossover for it especially if you dont have them on the car it would be cheap maybe 30 bucks tops and thats pushing it. Scottydoggs just had his moved to that location without any ill effects.
    2012 F150 STX
  8. #8 Re: Anyone (recently) bought and installed SD headers?
    i did,,,,ninja!
  9. #9 Re: Anyone (recently) bought and installed SD headers?
    Apr 2012
    Dayton, OH
    I'm too slow for ya
    2012 F150 STX
  10. #10 Re: Anyone (recently) bought and installed SD headers?
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    You guys have me convinced. With that little O2 sensor job like ScottyDoggs, for the price, these are just the way to go
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  11. #11 Re: Anyone (recently) bought and installed SD headers?
    Oct 2011
    Puyallup WA
    You have pacesetters don't think you need to relocated the O2 sensor
    08 G8 GT - exhaust Tune
  12. #12 Re: Anyone (recently) bought and installed SD headers?
    Mar 2014
    Cincinnati, OH
    Quote Originally Posted by wa04compg View Post
    Yepp. But when buying new, this route just seems to be the best
    2002 GTP sedan:
  13. #13 Re: Anyone (recently) bought and installed SD headers?
    Sep 2014
    Puyallup, WA
    That's slick. I was contemplating having extra bungs welded in to move the 02 and for a WB. Any chance of ill effects though on the crossover only taking reading from one bank?
  14. #14 Re: Anyone (recently) bought and installed SD headers?
    not at my mod level im told. rockers 3.4 and headers. so far so good.
  15. #15 Re: Anyone (recently) bought and installed SD headers?
    Sep 2014
    Puyallup, WA
    Last one... 2.5 or 3"band clamps needed?
  16. #16 Re: Anyone (recently) bought and installed SD headers?
    2 of each.
    2, 2.5's for the cross over, and 2, 3 inch for the down pipe. i got a torctight for 10 bucks at napa. the rest are the flat band clamps, they work just fine too.
  17. #17 Re: Anyone (recently) bought and installed SD headers?
    Donating Users Uno99's Avatar
    Appleton, Wi
    The crossover is 2.25"
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  18. #18 Re: Anyone (recently) bought and installed SD headers?
    it is, my bad on that one. or 2 1/4 same as 2.25
  19. #19 Re: Anyone (recently) bought and installed SD headers?
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I believe I have a 2.5" bandclamp on the crossover for my SD's and it's working fine. Just a heads up
  20. #20 Re: Anyone (recently) bought and installed SD headers?
    Appleton, Wi
    I just replaced the 2 band clamps on the crossover last week after finishing my rebuild. I bought 2 1/4 inch
  1. installed headers need help
    By m17davis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-20-2011, 01:49 AM
  2. SD Headers installed and A+++++
    By DCVING in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-07-2010, 06:56 PM
  3. Recently bought a 2002 Pontiac Grand Prix SE
    By WoodJen25 in forum Visual/Body Modifications
    Last Post: 12-02-2009, 09:10 PM
  4. Recently bought a 04 GT
    By Fubisin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-31-2009, 10:57 PM
  5. If you recently bought an aftermarket radiator from ZZP or W-Body store
    By Gandalf in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2008, 11:06 AM
