Thread: exhaust leak
Results 1 to 20 of 33
  1. #1 exhaust leak
    Donating Users
    Aug 2014
    Utah
    Hello,
    I suspect I have an exhaust leak near the rear manifold on my 06 Grand Prix. When it's cold its loud and after it warms up it quiets, i'm guessing the metal expands and seals with heat. How difficult is it to remove the rear manifold?
    Thank you
  2. #2 Re: exhaust leak
    Banned
    Jan 2013
    Colorado
    not too bad depending how rusted and corroded the bolts are
  3. #3 Re: exhaust leak
    Got a fog machine?? I'd send fog/smoke up the tailpipe and figure out what spot is leaking.
    Would make it eaiser to tell if it's the rear manifold or the downpipe flange leaking.
    Otherwise removing it isnt hard, just time consuming and you might break a couple exhaust crossover bolts, they tend to snap alot.
  4. #4 Re: exhaust leak
    GT Level Member xxburkettxx07's Avatar
    Topeka, ks
    Having the same problem with my 98gtp
  5. #5 Re: exhaust leak
    Donating Users
    Aug 2014
    Utah
    Does it come out the top and what has to be removed? Thank you.
  6. #6 Re: exhaust leak
    I tried to help, but nobody ever listens. The internet is great.
    Google it, search it on here if you REALLY want your answers, nobody is gunna sugar coat this **** for you.
    Crossover, rear manifold, egr, air pump brackets if cali car, other various brackets, downpipe bolts etc all come out.
  7. #7 Re: exhaust leak
    HUDSON
    I also had to do this due to the factory steel shim gasket leaking. I found it easiest to remove the two dog bone mounts and use a ratchet strap to hold the engine forward a couple extra inches. Also, removing the transmission dipstick gives more room, place a drain pan under the transmission and remove the bolts holding the trans. dipstick in place and then pull out, fluid will come out, that is what the pan is for. I was able to access all manifold bolts from the top this way. I used the Felpro graphite impregnated exhaust manifold gaskets and it worked well, the replacement manifold was a ported unit from a popular vendor I purchased 4 years ago. It had about .060 warpage on the head side flange at one end but still sealed, so some warpage is probably unavoidable.
    My stock unit had even more warpage, It would be possible to machine the flange straight but the crossover pipe mount would need to be cut off and then re-welded back into place after machining, as it gets in the way of the equipment.
    Hope this helps!
  8. #8 Re: exhaust leak
    GTP Level Member buickman104's Avatar
    NYC
    I posted this on another thread but figured it might interest someone on this thread.
    I saw this product on Jay Leno's Garage that looked interesting called "Lab Metal High Temp". It is a liquid metal puddy-like substance that you can coat on cracked manifolds, cross overs, headers, etc. to fill in and permanently seal the cracks. You coat it on less than 1/4 inch and let it air dry for 12 to 18 hours then you bake it by running the car for an hour to cure it. I am looking to test this product when my power log eventually cracks.
    Here is the link to the video
    http://youtu.be/RWisGeUpHHc
    Just search for "lab metal high temp" on your favorite search engine and check for prices.
    If anyone has a cracked manifold and would like to try this method of resealing please try it and let us know!
    If anyone wants to try it as a cheaper or easier solution if the leak point is easily accessible.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  9. #9 Re: exhaust leak
    Donating Users
    Aug 2014
    Utah
    i need to look into removing the two dog bone mounts, maybe then i can see an access a little better. Did it bind up the exhaust when you pulled the engine forward?
    thank you
  10. #10 Re: exhaust leak
    Topeka, ks
    As long as you disconnect the down pipe first you should be good to go
  11. #11 Re: exhaust leak
    You can yank the engine forward that little bit w/o disconnecting the exhaust.
    If you want to know where it is and are a reasonable person.. put the car on ramps while cold .. jump under and or move your hands around the seams of the exahust.. you don't touch it.. but you'll feel the breeze the leak creates.
  12. #12 Re: exhaust leak
    Donating Users
    Aug 2014
    Utah
    So this local mechanic said he will charge $520 to install a new rear exhaust manifold and he gets his parts from the Chevy dealership. The part is $225 and his labor is about the same plus tax. What didn't make sense to me was he said he will cut behind the cat and re-weld it. He said that the exhaust manifold is stainless steel that's why it's expensive. Seems to me the front manifold is cast iron I would think the rear is the same too.
    Any thoughts on all this?
  13. #13 Re: exhaust leak
    The rear is cast iron as well.
    04 Comp G.
  14. #14 Re: exhaust leak
    GTX Level Member SnowTh1ef's Avatar
    Aug 2013
    Sandy, UT
    might as well buy speedy daddy headers and pay for install at that point.
    04 GTP -HAI, 1.9 rockers.
  15. #15 Re: exhaust leak
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    I'm with Snow. I bought my Speed Daddy Headers off of ebay. I think they were like $217 buy it now? I offered $197 and got them instantly. And that is with shipping. And headers will remove a good deal of knock from your car
  16. #16 Re: exhaust leak
    Donating Users
    Aug 2014
    Utah
    Quote Originally Posted by tomtom123 View Post
    What do you mean knock, like pinging knock? Are they easier to install than the factory ones?
  17. #17 Re: exhaust leak
    Aug 2011
    Michigan
    Knock as in knock retard. When the car sees knock it pulls, (retards), the timing. Knock is what will kill pistons. The less KR, Knock Retard, you see, the better off you'll be.
    I wouldn't necessarily say they are easier to install. But if you're going to have a shop put on a new original manifold and the manifold is $225, for that price you can get a nice set of headers and increase your exhaust flow. The more exhaust out, the happier your car will be.
    It's also a good idea to do headers now if you ever plan on modding in the future. With the headers, you may be able to drop to like a 3.5" pulley if you have 0 KR. But thats a seperate conversation. A good place for info on that is on these forums. "Safely Modding Your 3800".
  18. #18 Re: exhaust leak
    Donating Users
    Aug 2014
    Utah
    I looked underneath and sure enough the exhaust manifold looks like SS. It be nice if it is just a manifold gasket leak that needs to be replaced but still it's in such a confined area. Does Speed Daddy headers require and special modifications? Meaning cutting, welding, removing etc. I can't remove any of the EPA garbage that i would like such as the cat or egr and also it looks like it would create a lot more heat under the hood. Sucks that i just spent over $200 for the crossover pipe two weeks ago, the original was cracked.
    tomtom123; did you do your headers yourself and what all was involved?
  19. #19 Re: exhaust leak
    i just did headers, its like 6 bolts a manifold take the down pipe off, un bolt the manifolds and cross over, install the new headers. theres a how to here. its not all that bad to do, a few hours work.
    sd headers you need to move the o2 sensor, or hammer the fire wall so it dont hit.
    i moved mine to the lower part of the crossover pipe.
  20. #20 Re: exhaust leak
    Why do exhaust threads always lead to someone saying headers this and headers that.
    Think about it guys, not everyones want to go that route or even has a ****ing clue what they are and what they do. Nor do they know whats involved with them and the fact that speedy daddys header are not plug and play, they have issues and many at that. Then if he has emissions he has to buy ANOTHER cat and thats more money and what if his check engine light comes on because of it. They/he likely has NO clue about computer tunes and likely has NO idea what any of that means and how he can get it done. And in the end it COSTS MORE money. I really wish people would think before they type, this is exactly why threads go on for pages with useless infomation like this thread already has.
    The rear exhaust manifold is cast, not stainless steel. They never came with SS, it was a mass produced motor and more cost effective to go with cast.
  1. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  2. gtp exhaust leak??
    By tichota126 in forum General Tech Discussion
    Last Post: 05-27-2012, 10:39 PM
  3. 3.1 water coming from exhaust leak on exhaust manifold
    By ibhuff in forum 3.1L V6 (LHO/LG8)
    Last Post: 10-21-2011, 01:54 PM
  4. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
  5. Need help with an exhaust leak
    By thenervemann in forum General Tech Discussion
    Last Post: 04-26-2009, 09:28 PM
