Thread: broken rod, disintegrated piston
Results 1 to 18 of 18
  1. #1 broken rod, disintegrated piston
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    has anyone ever made a piston disintegrate? ive had a tick/knock for 2 weeks, only maybe drove it 2 times with the ticking, when the car finally quit i wasnt even riding it hard, was just leaving a movie and bang, the car was done, turns out one piston is in the oil pan shattered, another has a broken rod, and i cracked the block by the dipstick tube, any idea how this all happened? i always run 91 octane
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  2. #2 Re: broken rod, disintegrated piston
    Assuming you are SC, you want to run the highest octane available.
    But sure.. I've bought a car with a missing piston
    No worries, you'll find that piston
  3. #3 Re: broken rod, disintegrated piston
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    It just happens, 98bucksupercharged went through 2 motors. Replaced his one that ejected a piston with another and that blew on the test drive or something lol.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  4. #4 Re: broken rod, disintegrated piston
    HUDSON
    Had a friend with a 67' cougar with a 289, and blew the piston out too, KNOCK!
  5. #5 Re: broken rod, disintegrated piston
    Apr 2012
    Dayton, OH
    Bill can I use that last picture for when people ask if they can run a 3.4 on just a CAI lol
    2012 F150 STX
  6. #6 Re: broken rod, disintegrated piston
    GTP Level Member 97AutoXVette's Avatar
    Mar 2014
    Cincinnati, OH
    haha, that is perfect!!!
    1998 GTP sedan: sold, 1999 GTP coupe #1: sold, 1999 GTP coupe #2 on E85: totalled
    2002 GTP sedan:
    3" downpipe|PLOG|poly mts|160 T*|60# Injectors|ZZP Intake|1.8 YT RRs|Ported Gen3|Ported ZZP S2 TB|E85|FP rewire|ZZP FSIC|WP UD Pulley|2.8 MPS|HP-Tuners
  7. #7 Re: broken rod, disintegrated piston
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Been there and done that. I had a valve that dropped trashing the piston. Just an innocent tick noise that was very faint then BAM......2 pistons laying on the highway. Should have taken pics of the damage.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  8. #8 Re: broken rod, disintegrated piston
    Jun 2014
    Ontario Canada
    LOL billboost37, thats exactly what it looked like on my number 4 cylinder, just ALOT more pieces, my number 3 piston broke a connecting rod and then hit the front of the block cracking it all the way across, i believe the oil pickup failed because i found one sheered off bolt and the other was gone, looks like its time for a new motor after winter time :P
  9. #9 Re: broken rod, disintegrated piston
    Enfield, CT
    This happened to me before. it was fun. Heard the knocking and drove hard for around 20-30 miles and bang lol. Only an N/A motor tho.
  10. #10 Re: broken rod, disintegrated piston
    Jun 2014
    Ontario Canada
    mines s/c looks like the exact same piston as mine that it happened, #4 near the firewall
  11. #11 Re: broken rod, disintegrated piston
    Donating Users Uno99's Avatar
    Appleton, Wi
    That oil pan pic is nuts man WOWERS!
    02 GTP VS CAM / 3.2 MPS / CAI / SD HEADERS Catless DP & E-Cutout / AEM WB / HPTuners
  12. #12 Re: broken rod, disintegrated piston
    Jun 2014
    Ontario Canada
    This is my piston :P
  13. #13 Re: broken rod, disintegrated piston
    Appleton, Wi
    That must have sounded horrendous when it let go.
  14. #14 Re: broken rod, disintegrated piston
    Jun 2014
    Ontario Canada
    Didnt sound bad actually, was relatively quiet for how much damage happened, i was suprised at how bad it got damaged, i knew when it would roll over and bind that the motor was done, and the smoke from under the hood over my hid's :P
  15. #15 Re: broken rod, disintegrated piston
    Appleton, Wi
    I just spun the #1 rod bearing in my car and am just heading out to start assembling the bottom end. What do you plan on doing now?
  16. #16 Re: broken rod, disintegrated piston
    Jun 2014
    Ontario Canada
    well its only a summer car for me, so looking for a dd/winter car while i find a used motor to fully rebuild, plans are, cam, headers, valves, springs, .20 bore with forged pistons, colder plugs, and maybe 3.4 pulley depending if those mods can sustain it, never worked with a supercharged car before, only older chevy 350's
  17. #17 Re: broken rod, disintegrated piston
    Appleton, Wi
    Well good luck man. And with a cam and headers you can Def run 3.4. On my old S1X cam'd 98 gtp I ran a 3.0 Just make sure you get something to scan for knock and tune after investing all that.
  18. #18 Re: broken rod, disintegrated piston
    Jun 2014
    Ontario Canada
    Yeah id definatly scan it/ get it retuned at a speed shop
  1. WTB connecting rod and piston
    By jfichtner in forum Wanted To Buy - Parts
    Last Post: 05-04-2013, 11:19 PM
  2. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  3. clutch piston?
    By murp9302 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2010, 10:53 PM
