Thread: Camshaft?
Page 2 of 2 FirstFirst 12
Results 21 to 39 of 39
  1. #1 Re: Camshaft?
    GT Level Member popeyenate's Avatar
    Jan 2009
    san diego
    so im guessing the xp or xpz is too wild for top swap with slightly worked heads and i/c? dang...well disregard my one post about cam question then...lol
  2. #2 Re: Camshaft?
    XP is a great cam...I street'ed it everyday in all conditions...you can run a XP just fine on stock heads...it is the XPZ that needs a bit more love.
  3. #3 Re: Camshaft?
    XPZ doesnt need ported heads to run it, but it needs ported heads to run well. it is a smaller cam, but makes a ton of power on the right setup.
    i personally wouldnt buy any of ZZPs cams unless i wanted to pick up a NIC.
  4. #4 Re: Camshaft?
    Jan 2009
    san diego
    maybe i should just pick some lobes and degrees i want and call up comp and grind me one, or just call and ask them what would be good with my parts...
  5. #5 Re: Camshaft?
    Banned - Busted For Scamming
    Feb 2009
    cammed setups cost too much money IMO
  6. #6 Re: Camshaft?
    They cost money because they make power...and if tuned right rape most anything.
  7. #7 Re: Camshaft?
    Donating Users blowfishRus6's Avatar
    g.a.
    intercooler set up is gonna cost some money too. core, front mount, pump. probably gonna come out about the same in the end.
    white 04 comg G gtp. wizair, pacesetters, slp 1.8 rr
    its slow.
  8. #8 Re: Camshaft?
    Jan 2009
    san diego
    ic: 400
    fmhe: Air to Water Radiator (whats difference between this and 101?)
    pump: 79.99 with 1/2 fittings
    ZZ Performance
    and hoses...whatever per foot at 1/2" so its a decent setup, would be about the same...cam can wait i agree...for same price i should get the obx headers huh?
  9. #9 Re: Camshaft?
    g.a.
    ss autochrome. heard bad things about fittment issuies with obx i do belive.
    its slow.
  10. #10 Re: Camshaft?
    What IC costs $400? Unless you are building it all yourself...which should be fun...
  11. #11 Re: Camshaft?
    Jan 2009
    san diego
    yeah, just clamp it all up then go to muffler shop to weld it in. minichopper has obx and he says for price cant be beat, just get someone to weld them up. looks like could be bolted together...but i dont trust clamps for too long...so i guess the ic setup is even more than the cam...maybe i should hold off on ic and cam til later? do it in stages...lol. it would be about 800 up front then, then about 600 later, then another 400..so for about 2k i can have a decent setup, not too bad at all i would say!!
  12. #12 Re: Camshaft?
    g.a.
    minichopper's full size intercooler core is 450. then pump and front mount
    its slow.
  13. #13 Re: Camshaft?
    Jan 2009
    san diego
    i have been talking to him about stuff, and we have discussed prices but yeah, mount it all up and plumbing...i am aware. i think i will just do it in stages if i do it. s/c first with mps, 3.4 should be ok, and headers. then next step is cam OR ic, or vice versa...could do both same time, if i have the extra money...lol
  14. #14 Re: Camshaft?
    Just be sure not to drop pulley sizes until you let it breathe...knock is what destorys these cars...too small of a pulley and you go boom
  15. #15 Re: Camshaft?
    Feb 2009
    DONT buy the obx unless you have access to a welder. They dont include clamps, and you wont be able to anyways, they just werent made right. Also, the crossover is all wrong, you have to cut and reconfigure it. Otherwise, they are decent, so if you have a welder, you have good headers for $350 and exactly like the ss ones with one joint
  16. #16 Re: Camshaft?
    Jan 2009
    san diego
    Also, the crossover is all wrong, you have to cut and reconfigure it. Otherwise...
    u have a pic of this?
  17. #17 Re: Camshaft?
    Feb 2009
    if you buy that pump with 1/2" fittings, you will be restricting the core. The one i use has 3/4" inlet/outlet.
  18. #18 Re: Camshaft?
    Feb 2009
    not really they are on my car and you cant see about 80 percent of them lol when i take them off ill shoot some pics if you want.
  19. #19 Re: Camshaft?
    Jan 2009
    san diego
    ok cool man, sounds good to me. they have larger inlets/outlets for pumps? nvm, im lookin now..thanks for the info...
  1. Trouble History With Camshaft Position Sensor
    By SyntheticShield in forum General Tech Discussion
    Last Post: 06-04-2009, 01:21 PM
