Thread: Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
Results 1 to 6 of 6
  1. #1 Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Fired this pig up and it ran fine several times, fired it up again and it has the loudest high pitched whistle I have ever heard. Clearly a vacuum leak around the snout side of the supercharger, confirmed with a dousing of carb cleaner on that side of the blower. rough idle, change with spray. Do I even bother with gaskets if they dont survive the dismantle. Or just squirt a tube of high temp grey or red RTV between all of the upper pieces and call it good? Or get 2 more new gaskets add RTV to them and re-samich them all together? I've properly blocked off the LIM to throttle body coolant passages. No EGR. and I am 99% sure there is no leak between the intercooler plates. the leak seems to be at the supercharger to intercooler plate.
    I've seen a vac leak before around the snout side water tube before, and a pile of RTV fixed it. I hate to resort to the RTV all over everything method to fix the vac leak but it seems like that's the only option at this point. Is a vacuum leak at the intercooler a common thing?
    I'm tearing it all apart again in like 7 hours. I hope I get at least a few opinions in this short time frame.
  2. #2 Re: Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    May 2012
    Where winter never ends
    When I was running a SC intercooled setup, I just used grey silicon. Screw gaskets, especially garleaks from ZZP. 1 con to silicon is its a pain in the ass to get the thing apart again but with some pry tools and force itll pop.
    2000 Regal - Winter Beater
  3. #3 Re: Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    Kemmerer, Wyoming
    I have no experience on this matter, but I have read that sseilop recommends using only grey permatex when installing an intercooler.
  4. #4 Re: Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    Feb 2014
    Milwaukee
    I no u have a vac leak as your saying. But u might have blocked off the pcv passage too. Take off the oil cap and see if it goes away. Just saying. But I mean that noise can come from that too
  5. #5 Re: Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by johntremell View Post
    same stuff I used when I sealed mine and it was good but it might take a couple tries to get it right.. op you hav any e85 stations f**k sealing and run corn lol
    Sent from my LG-E980 using Tapatalk
  6. #6 Re: Double SC gaskets, no gaskets, gaskets and RTV, what do?!? (Intercooler) Vac Leak
    SE Level Member wyoprix's Avatar
    cheyenne wy
    just did
    3 days ago its a hybrid phenolic style
    cleaned an wired wheeled it some kept the lower metal gasket an used hight temp red under it over it an on top of the intercooler an took the bolts down but not tight just snug an let it set for 6 hours then tighten them an had no leaks also deleted the egr an pluged the egr inlet an changed out all my vacum hoses with heavy duty high temp silicone lines after noticing the old ruber ones were cracking
    2007 gt 3.0 mps 0-KR headers 3''dp cat res delete 44 injectors 85MAF stage 3 intercooler 108 t stat cold air, overkill pcm, aeroforce gauges tripple pillar, rims tint, trans cooler intense shift kit, yella terra 1.9 roller rockers 105 crow springs, 104 plugs, 7'' pioneer screen 1000 watt rockford amp an two 10" P3's cusom box & more
  1. SS intercooler install + LIM gaskets question
    By tonglebeak in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-25-2012, 07:05 PM
  2. Possible vacuum leak/replacing gaskets
    By nik12937 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-26-2012, 10:46 PM
  3. VC gaskets
    By dwelles in forum General Tech Discussion
    Last Post: 08-08-2011, 04:10 PM
  4. LIM Gaskets
    By RICE KILLER in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-25-2010, 01:24 AM
  5. Cutting S/C gaskets for S2 Intercooler
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2008, 05:26 PM
