Thread: Top Swapping and Spark Plug Question
Results 1 to 17 of 17
Threaded View
  1. #13 Re: Top Swapping and Spark Plug Question
    Jul 2014
    colorado
    Parts needed for top swapping:
    Heads from l67
    LIM from l67
    Throttle body and sensors
    Vac lines
    Fuel rail and injectors(depending on the year of the na you might need the injector connectors)
    Valve covers
    All sensors (maf,map,tps,iac,) for the map youll need a top swap kit i orded mine from zzp its a wiring harness for the map sensor as they have different connections
    I agree with new head bolts as well as they are one time use torque to yield
    Icm bracket with tensioner and idler pulley
    Second idler pulley by the harmonic balancer
    Harmonic balancer from l67
    Tuned for top swap pcm again people bash zzp for the ecm or pcm canned tunes but because you have modified add ons youll definitely need a real tune.
    All gaskets from the heads up :
    Head gaskets
    Lim gaskets ect these usually come in a pack all together and they have literally everything from the heads up and are like 70-100 bucks. Felpro gaskets are what people recommended me.
    Also yes torque wrench will be needed regardless.
    Trouble i had on mine was removing the tensioner pulley assembly i broke mine, also dont put the tensioner on the icm on wrong because it will cause the belt to slip off (personal experience )
  1. Spark plug question
    By BigKev2403 in forum General Grand Prix Discussion
    Last Post: 03-05-2013, 04:54 PM
  2. PCM and spark plug question
    By jjwalton77 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2011, 05:31 PM
  3. Spark Plug Question.
    By DnaProdigy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-14-2011, 09:45 PM
  4. Spark plug question
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-27-2011, 03:44 PM
  5. Spark Plug question
    By Kenny75k in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2010, 09:04 PM
