Yep. It's either a junkyard or car-part.com. Don't bother rebuilding it. Just get a low mile motor and swap it in. Since I don't know what year you drive I'd say you're looking at anywhere from $400-$600 for a decent used one. Could be less depending on the mileage.
Reason is, these motors MUST have machine work done to the entire bottom end to even think about lasting more than 100 miles after the rebuild. The cost of the machine shop work plus the "rebuild" kit outweighs the cost of a used motor, plus the used motor just swaps in. Pull out the old, drop in the new, move on. Since you have the VS cam while the motor is out would be a good time to replace all the gaskets/seals that are common to leak on these engines as well as swap in the cam.
How did you spin a bearing might I ask?
