Cheap ****ty pistons that have seen KR for years are going to be weak as hell.
Also, apparently L36 rod bolts like to let go from time to time. It's a fun time, when you're spinning into the mid 6's on a stock bottom end.
Mmm, all that quench.
my last few engines have all been 150$ scores from burn victims with mostly intact valvecovers.
junkyards assume they are junk, and if you dont mind itchy arms for a day or two you can get a damn good shortblock for a damn good price. as long as you know what yer looking fer.
granted up here in the rust belt we have plenty of good powertrains with rotten shells, down south you have clean shells with junk powertrains.
People have been top swapping L36 and L26 for years. They work, they are plentiful, they are Cheap, and they have low miles.
If you got the money to spend get a L67 L32 or better yet get a RWD car with a V8 stick and all the things we aren't.
I'd still avoid the L26 like someone with the clap.
No thanks.
Get an L36, all day long.
l26 would be fine but realize that they are more hit and miss than the older l36. the tooling was wearing out. main galley alagnment from both ends of the block suffers greatly the newer the motor build date. its one reason all the die casting dies were reworked for sand casting...cheaper than repairing the production die casting machinery.
if ya were goin to sub 2.8 territory with a chance at spraying it id shoot for a cast rod l36....ive seen enough l26 carnage to know that i really dont wanna push one more than a nice mild DD setup.
i dunno 'bout yew...but i dont like the idea of PM rods that are designed to fracture....with a lovely chicken neck beam that'll snap if you look at it wrong....
