Thread: 2000 GTP RPM stalling out issue
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: 2000 GTP RPM stalling out issue
    Jun 2013
    Hollywood ,FL
    quick question im having the same issue i just swapped my crank ensor with a cheap bwd one same symptoms happen when the car gets hot but once car stalled i removed my ignition wires and checked for spark on my coil packs while turning the ignition would your coil packs still spark once your car died? i ruled out my icm since all 3 packs were sparking apon starting. i just ordered an acdelco crankshaft sensor due to im sure its made better then the bwd brand
  2. #22 Re: 2000 GTP RPM stalling out issue
    Sometimes an ICM can fail like that when hot.
  3. #23 Re: 2000 GTP RPM stalling out issue
    Jun 2013
    Hollywood ,FL
    Yes but if it failed why would coil packs still get spark
  4. #24 Re: 2000 GTP RPM stalling out issue
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Could be as it gets hot the spark weakens which is what I believe Bill was getting at. Thr plate might be coroded or something and as it requires stronger/more/faster sparks it ends up failing enough to stall. Just some thoughts
  1. Stalling Issue....Please help
    By SCbuick010 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-09-2012, 07:15 PM
  2. 2000 grand prix gt stalling issue
    By 2000gts in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-28-2011, 08:36 PM
  3. Stalling Hot Issue Need Help...
    By BPGPSE in forum General Tech Discussion
    Last Post: 06-13-2010, 09:26 PM
  4. New Here and Have Stalling Issue
    By BPGPSE in forum Introductions/Noob Questions
    Last Post: 06-12-2010, 07:14 PM
  5. MAF / stalling issue
    By the1euge in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-14-2008, 11:16 AM
