so i guess i should stick with the xp that i here? and just run stock rockers? till i can get a set of 1.6 rockers? well i appreciate the help you guys are givin just do not want to make a bad choice on the cam cause it will in there for awhile.
Factory rockers after 1999 are 1.66 ratio. 96-98 rockers are 1.6
Agreed. Ron showed me the light on this too. If you are talking about the old school stamped crap like I had in my stock SBC, yes, I could see how that piece of junk could deflect. But after getting my modded stockers recently, they look well engineered to my untrained eye. Metal can flex more than you'd intuitively think, but I would not worry about those suckers doing that at all. I'd think the push rod or something else will give first.
That ZZP test is depressingly short on details. How they came up with the disparity in lift could have come from something other than the rockers. Not to mention they were testing the 1.9 with a #130 spring. I don't imagine many people have that combo. Even if it is accurate, they claimed the effective ratio was 1.87 on the 1.9. Close enough for me.
This not apply to the JP?Remember, if using the Rollmaster, it was developed for the L36, so it may be retarded 2 degrees when installed straight up in an L67.
