Thread: Front and Rear O2 Sensor readings
Results 1 to 4 of 4
  1. #1 Front and Rear O2 Sensor readings
    Jul 2012
    Bad Axe, MI
    What are considered normal readings for the front and rear O2 sensor readings??
  2. #2 Re: Front and Rear O2 Sensor readings
    bank one's voltage should should dance up and down rather quickly.
    no idea on the rear o2, in the early years it dont do much.
  3. #3 Re: Front and Rear O2 Sensor readings
    Front will fluctuate from say 100 or less to 800 or a little over.. then some in the midst.. The faster the readings change the better.
    Never honestly looked at a rear sensor reading.
  4. #4 Re: Front and Rear O2 Sensor readings
    SE Level Member transam24's Avatar
    Dec 2011
    NY
    If you look at a rear sensor on a graph it should remain steady if the cat is doing its job. If not it will fluctuate like the forward 02 sensor
  1. 0 KR rear sensor & 5-7 degrees KR front sensor
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2013, 08:06 PM
  2. GMPP front and rear sway w/ front STB
    By FordMan77 in forum General Grand Prix Discussion
    Last Post: 10-31-2012, 03:04 PM
  3. Question about tps sensor readings.
    By cameron92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-27-2012, 05:53 PM
