Thread: Pending p0128 code today
Results 1 to 19 of 19
  1. #1 Pending p0128 code today
    Aug 2013
    Kitimat, B.C.
    It popped up on the scan guage today. It was about 15c and when I shut the car off I noticed the fan was running which I couldn't hear over the exhaust. I think the guage said the coolant temp was 80c. It's been that way all summer, even if it's 25c out, it never got to 100c. I have heat extractors in the hood to aid in airflow through the radiator. I double checked the coolant a couple weeks ago and it's full. This is in a fiero
    86 Fiero se convertible 3800sc 4t65e HD(2002), Gen V, 3.3 pulley, SD headers
  2. #2 Re: Pending p0128 code today
    Off memory.. it's 128 typically a thermostat stuck open?
  3. #3 Re: Pending p0128 code today
    Aug 2013
    Kitimat, B.C.
    It points to that or the cts. I don't think its the cts as at the beginning of the day the ait and cts are the same and the cts goes up as the engine warms up. I like the fact that i'm running cool like that.
  4. #4 Re: Pending p0128 code today
    Keep in mind... you are only seeing one of the two ECT sensors that are built into the single package sensor that we replace.
    If the pcm tossses a code and the dash is correct. It's wiring or sensor.
  5. #5 Re: Pending p0128 code today
    Aug 2013
    Kitimat, B.C.
    could you elaborate more on the sensor your talking about? Does that mean there's two different sensors on the motor or just the one that has two readings? The thing with the fiero dash gauges is they ain't reliable, mine barely goes to 1/4 on the guage but that might be correct just hard to tell with the lack of numbers.
  6. #6 Re: Pending p0128 code today
    id check the t stat, if its open you found the problem. stuck open will run to cold. these engines like to run at 210.
    the temp sensor under the t stat, it sends info to the pcm. and the cluster gauge, some times 1/2 of the sensor quits working, or the wires are cooked from the heat of the cross over pipe.
  7. #7 Re: Pending p0128 code today
    Aug 2013
    Kitimat, B.C.
    Ahh gotcha, will look at the sensor. Just to learn me, I know the thermostat stays closed until it reaches it's temperature. Once it's open, won't it cool back down to where it would be if it was stuck open? Like in my situation, I'm usually around 80c (say it's stuck open) and I replace it with a new one. The temp gets to 180 and opens, won't my temps eventually go back to what I'm seeing now? I'm hoping I have a kick ass cooling system and never have to worry bout it overheating. And I do have heat out of the heater.
  8. #8 Re: Pending p0128 code today
    You had mentioned that the coolant temp aka engine coolant temp (I noticed I used a different acro than you). The S2 has two sensors built into the one unit. There's three wires. One incoming and two outgoing. Of the two outgoing one feeds the pcm and the other feeds the dash gauge. Your mention of the CTS/AIT etc led me to believe the dash was reading the correct temp. Which would mean the code is being thrown based on a bad sensor to the pcm.
    I'd prefer to check the reading of the pcm coolant temp with a scan tool. If the engine warms up and the temp doesn't read the change, then it's the sensor, if the temp of the engine actually does not warm up fast enough, it's a t stat
  9. #9 Re: Pending p0128 code today
    when a t stat fails they can fail open, or closed. (depending on the brand) when stuck open it can run to cold.
    180 t stat is to cold too. put a 195 in like it wants. modded or not the engine runs its best around 200 to 210. getting cooling temps down is old school stuff dont apply to these newer engines.
  10. #10 Re: Pending p0128 code today
    What out Scott...
    He's BC. One sentence he's talking C's and then a moment later he says 180...which has to be F's Then northern neighbors of ours are always trying to trip us up
  11. #11 Re: Pending p0128 code today
    Aug 2013
    Kitimat, B.C.
    What out Scott...
    Lol, wasn't aware the 180 was f. So I need to figure out what that is here. But since I'm changing thermostats, I will be modding the motor in the future should i go for the lower one? Keep in mind this is only a summer driven vehicle.
  12. #12 Re: Pending p0128 code today
    this is a US based site. so i talk degree's damn it lol i dont do canuch temps hahahahaha.
    195 fahrenheit t stat always, year round.
    i went the extra mile for ya. 195 is the same as 90.5556 c
  13. #13 Re: Pending p0128 code today
    212F = 100C
    32F = 0C
    If you are seeing close to 100C then you are at the normal T stat which is 195F
  14. #14 Re: Pending p0128 code today
    Aug 2013
    Kitimat, B.C.
    212F = 100C
    32F = 0C
    like I said in the title it's pending. So it seems like the temps are normal then. So I wonder what might be issue. I might just wait to see if it actually pops up.
  15. #15 Re: Pending p0128 code today
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    Quote Originally Posted by tweeder View Post
    I would delete the code and drive the car a while and see if it comes back. I usually do this two times to make sure it's actually a problem and not just the computer remembering that at one point in time this problem had occured
    Sent from my SM-N900P using Tapatalk
  16. #16 Re: Pending p0128 code today
    i see Bill went a mile further lol
  17. #17 Re: Pending p0128 code today
    Which..is way longer than a Kilonomonolomter
  18. #18 Re: Pending p0128 code today
    lmao.
  19. #19 Re: Pending p0128 code today
    100KPH is 62.5mph.. wanna talk about feeling lethargic while driving. Can't speed, cause you are in another country...
  1. i need help with a p2430, p2431, p0128 code on my 2006 -GP
    By KIEANA in forum General Tech Discussion
    Last Post: 04-23-2014, 05:53 PM
  2. P0128 code
    By TDgrand in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-24-2013, 09:33 PM
  3. repair code p0128
    By dnomaam1 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-10-2011, 12:28 AM
  4. Getting P0128 code in the summer
    By picghaw in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-26-2011, 11:42 PM
  5. Code P0128
    By trenaro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2010, 08:38 PM
