Thread: 2 broken pistons. What caused this?
Results 1 to 20 of 22
  1. #1 2 broken pistons. What caused this?
    sw mn
    Well the car is a 1999 GTP, 165k ish miles, zzp small pully and computer remap (not sure on size, was installed already when I bought car.) In December was leaving work at 2am and the temperature was 10 deg F. Car was warmed up 10-15 min before I left work. I drove around town before I went home for 5 or so min. (I live 1 mile from work and like to charge battery up good in winter before turning car off.) Was 2 blocks from my house and it started chugging and didnt have much power. I limped it home and when I pulled into the drive way thecheck engine light came on then I turned the car off. Checked fluids and belts and they were all good. Had car towed and inspected. They said at had a bent over plug electrode causing a miss fire and check engine light to turn on. Bore camera pitcures showed a piece of metal stuck to the head. They wanted $2k to pull heads and inspect and put all together with a used supercharger. (They were thinking supercharger went out and engine ate something.) I had them put it back in my driveway for me to look at when I get time. I bought a 2008 Grand Prix and let the 1999 sit.
    This weekend I finally pulled heads off and found 2 bad pistons. Not sure what caused it but seems weird how both pistons look broken exactly the same. See pictures.
    2 broken pistons.  What caused this? Attached Images
  2. #2 Re: 2 broken pistons. What caused this?
    Antioch, IL
    To small of a pulley and not enough mods
    2009 Challenger SRT8
    Expert at being gay.
  3. #3 Re: 2 broken pistons. What caused this?
    sw mn
    Trying to upload more pictures yet.
  4. #4 Re: 2 broken pistons. What caused this?
    Chipped pistons are cool.
    Running a smaller pulley without exhaust mods is a great way to make the piston weaker and I guess they both just decided to chip.
  5. #5 Re: 2 broken pistons. What caused this?
    Yup small pulley and not enough mods to allow you to run said pulley without knock
    04 Comp G.
  6. #6 Re: 2 broken pistons. What caused this?
    good old small pulley, and no mods, aka KR and chip chip er roo.
    it was a chunk of piston that smashed the spark plug.
    you do use 91 octane or higher too right? 93 or higher is preferred if you can get it.
  7. #7 Re: 2 broken pistons. What caused this?
    Feb 2013
    37.295091, -121.930053
    Thst sucks but you didnt have enough mods to support your "smaller" pulley. Untell you get headers, cam, ported heads and a tune dont even think about any pulley smaller than 3.8. It sucka you blew your motor but a simple question/reading will save you time and money.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  8. #8 Re: 2 broken pistons. What caused this?
    sw mn
    I cant get piston pictures to load but the piece that broke out was 1.5 inches by and .25 inches. Heads are not banged up and neither are the domes of the pistions. Its like a hammer knocked off the edge of the piston. It was on cylinders 3 and 5 i believe. I always ran 91 oct and sometimes 93 if they had it.
  9. #9 Re: 2 broken pistons. What caused this?
    Antioch, IL
    91 on a smaller pulley with no headers... time for a new engine whoop
  10. #10 Re: 2 broken pistons. What caused this?
    kinda like this?
    find a used engine drop it in there. yours is a scrap now.
  11. #11 Re: 2 broken pistons. What caused this?
    The damage was done before you bought it, they just let go when you drove it.
    The chip will break off and maybe hit once or twice and normally smack the plug tip and get sent out the exhaust valve right away.
    They always look like this and the middle cylinders are prone to it.
  12. #12 Re: 2 broken pistons. What caused this?
    sw mn
    Just like that but on 2 pistons.
  13. #13 Re: 2 broken pistons. What caused this?
    sw mn
    I had the car 4 years and put on 50k miles on it. Looks like I am parting it out. The real big bummer is I put a rebulit GM transmission in it 2 years ago and that has about 18k miles on it. That will be fore sale.
  14. #14 Re: 2 broken pistons. What caused this?
    Antioch, IL
    junkyard motor is $600 or under and you have a perfect running car again.....
  15. #15 Re: 2 broken pistons. What caused this?
    drop a used engine in it and sell it off, you;ll get more for a running car vs parts. invest a little more to get it back.
  16. #16 Re: 2 broken pistons. What caused this?
    Aug 2013
    McDonald PA
    Yeah that's stupid to part it out. A JY motor could be cheaper than that.
  17. #17 Re: 2 broken pistons. What caused this?
    Feb 2013
    Your going to sell your car for how much? Dont be a dumbass get a motor and get back up and running
  18. #18 Re: 2 broken pistons. What caused this?
    sw mn
    I was thinking about a used motor then sell it but the car is 2 hrs away from me. Thats the only place I can work on it. I'm just going to part what ever I can then junk the rest out.
  19. #19 Re: 2 broken pistons. What caused this?
    sell it whole you'll do better.
    as is, needs a motor 800 to a 1000 bucks and your out.
  20. #20 Re: 2 broken pistons. What caused this?
    Antioch, IL
    since you have plenty of money throw some my way. Ill give you $100 for ur car
  1. Hard shifting caused by fuel relay!?!?
    By Linebacker in forum General Tech Discussion
    Last Post: 02-25-2013, 07:37 AM
  2. Fluid exchange caused leak?
    By Performance nut in forum General Tech Discussion
    Last Post: 08-07-2012, 10:14 PM
  3. Bad CV Axle caused another issue?....
    By ajburks in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-03-2011, 01:45 PM
  4. Code p0300 misfire caused by cat?
    By randywalsh in forum General Tech Discussion
    Last Post: 09-05-2011, 09:44 PM
  5. issue caused by volt booster?
    By Warbeaver in forum General Tech Discussion
    Last Post: 05-10-2010, 02:11 PM
