Thread: Misfiring / stumbling at higher RPMs (video link)
Results 1 to 3 of 3
  1. #1 Misfiring / stumbling at higher RPMs (video link)
    Oct 2012
    vancouver
    I have had my 97 GTP for 7 years with no problems. Only routine stuff such as oil and brakes. In the past couple of weeks I have developed a significant misfire at 3.5k rpm - to redline. No check engine light. Replaced plugs, coil packs, fuel filter....no improvement. Anyone have any guesses or possible solutions? Keep in mind the video below actually shows less of a misfire than usual. It can be quite a bit worse.
    https://www.youtube.com/watch?v=i0rEoN3aMXM
  2. #2 Re: Misfiring / stumbling at higher RPMs (video link)
    St. Louis
    What kind of plugs did you put in it? Also, why not replace the wires? Could have damaged one (or more) when pulling them off the old plugs. Do you get a flashing CEL when it happens?
  3. #3 Re: Misfiring / stumbling at higher RPMs (video link)
    Oct 2012
    vancouver
    autolite 104s at the correct gap for a 3.4 pulley + supporting mods car. Wires will be next! No flashing CEL though.
  1. Harsh shuttering under hard acceleration in higher RPMs
    By machinegunsquid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-03-2013, 05:27 PM
  2. Bad outer tie rod end? Video link included
    By LoneGunman in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2011, 11:09 PM
  3. Engine Misfiring @ High RPMs
    By skiderek in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2010, 05:57 PM
  4. GTP with misfire at higher rpms or when boost starts to kick in
    By 00obgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2009, 05:27 PM
  5. Stumbling
    By duane9586 in forum PCM Tuning
    Last Post: 10-28-2008, 08:17 AM
