So the GTP has developed a nice problem.
Before we get into the problems, the background is
2002 GTP -75k miles.
Speed daddy headers, no cat, no rear O2
Homemade CAI
Rear o2 is just disconnected. No emulator, PCM isnt tuned yet. Popping the P0140 (no rear o2 sensor activity....I wonder why...)
Engine was pulled out 2 weeks ago, and reinstalled. No issues until a few days ago.
About a week ago, at low speed, the engine started to surge. As the car shifts from 2nd to 1st at very low speed, the engine wants to rev up, and the car wants to accelerate. This happens randomly. Giving it gas doesn't help. It will only go away on its own, randomly. Sometimes it lasts for just a blip, sometimes it'll last the entire time Im stopped. If I put it in neutral, it will rev to around 3k and hold steady.
I can hear the intake get louder when the car does this, like the butterfly isn't seating.
Now this wasn't a big issue, as it only affected very low speed operations about 20% of the time. Drivability wasn't affected.
Last night, merging onto I-95 to go to school I was around 75-80% throttle in 2nd, and the car started to buck/stutter hard. Almost like a misfire, but a little rougher. As soon as I let off, it went away. Once I was on I-95, I tried giving it gas again in 2nd. Didn't do it again until I went WOT. This time, around 5k rpm, it was even harsher. Felt almost identical to bouncing off the top speed limiter. Pulling strong, then dead on it's face for half a moment, then strong again.
It also randomly will rev from 2100 to 2400rpm while cruising. Again, this just started recently.
As long as I drive the car normally, there arent any issues. Only under hard acceleration, and at super low speed downshifting into first.
I've check the lines for a vacuum leak, and sprayed all the joints, without any change.
Not sure about the revving at idle, except for a dirty IAC/TPS, or lots of build up on the butterfly.
The random surge is far and inbetween.
After the harsh stuttering, the car popped a P01133 (oxygen sensor circuit slow response, upstream sensor)
I erased the code, car still stuttered, and the code hasn't returned.
I'm hoping it's all related, and not an issue with the trans (torque converter lockup)
I'll be heading home tomorrow to work on the car, as I have almost no tools here at my apt. (was going to swap blowers to my ported GenIII, and my other Stock TB(painted to match)
