Thread: Oil leak
Page 1 of 11 123 ... LastLast
Results 1 to 20 of 218
  1. #1 Oil leak
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    So I have been searching for the past couple of days and can't seem to find where I am leaking oil from.
    99 GTP just did an engine swap and replaced all of the gaskets from the top to the bottom. Including timing cover and oil neck gaskets.
    The oil appears to be leaking somewhere close to the power steering pulley when the car is running. Its hard to see where the leak is originating so I am kind of wondering if there are any common leakage areas that anyone knows of in this area?
    I put the tack seal stuff on with the timing cover gasket so I'm fairly sure this isn't where the leak is. But again, I'm not ruling anything out yet either. Thanks in advance
    Sent from my SM-N900P using Tapatalk
  2. #2 Re: Oil leak
    There's no common leak on a motor that was just sealed up. Hop under it and find your leak.
  3. #3 Re: Oil leak
    Aug 2011
    Michigan
    Alrighty. I was just wondering
  4. #4 Re: Oil leak
    The only other thing over there.. that would leak a lot is the oil filter adapter.. Valve cover gasket.. but you sealed it?
  5. #5 Re: Oil leak
    Aug 2011
    Michigan
    New upper intake, lower intake, head, valve cover, timing cover, water pump, oil neck (or oil filter adapter?), and rear main seal gaskets
  6. #6 Re: Oil leak
    Aug 2011
    Michigan
    And new oil pan gasket
  7. #7 Re: Oil leak
    Aug 2011
    'Merica
    Did you properly tq everything down or did you superman the bolts?
  8. #8 Re: Oil leak
    Aug 2011
    Michigan
    I don't have the torque specs for EVERYTHING, however 2 guys in Automotive where I attend college are the ones that torqued most of the bolts down while I did the cleaning and replacing of gaskets and parts and putting everything back together
  9. #9 Re: Oil leak
    Aug 2011
    'Merica
    I would double check everything that you guys did. Could have over tightened something, or under tightened something.
  10. #10 Re: Oil leak
    Aug 2011
    Michigan
    Alright. I'll see if I can find the torque specs and I'll ask the guys what they torqued everything to. I think I'll start with the oil filter adapter since it seems it might be the easiest thing to do thriugh the wheel well
  11. #11 Re: Oil leak
    There's a torque spec thread here..
    The main thing is consistency in torquing. But.. that also leaves you many possibilites for leak areas.
    Did you change VC grommets?
  12. #12 Re: Oil leak
    Aug 2011
    Michigan
    Yes sir. Everything is blue now =P
  13. #13 Re: Oil leak
    FelPro.. It's what I use.
  14. #14 Re: Oil leak
    Aug 2011
    Michigan
    Yup. I hear they are good. I have FelPro everything except the Victor Reinz head gaskets
  15. #15 Re: Oil leak
    St. Louis
    Might want to check the oil pressure sending unit. Remove the electrical connection to it and see if it's full of oil.
  16. #16 Re: Oil leak
    turn the front wheels all the way to the left, leave the engine running. then look from behind the back of the pass side wheel to the oil filter. you'll see the oil pressure sensor, if the plug end is wet its shot. this pos sensor will leak oil like a sob , aka fast.
  17. #17 Re: Oil leak
    Aug 2011
    Michigan
    This green sensor?
  18. #18 Re: Oil leak
    yes sir
  19. #19 Re: Oil leak
    Aug 2011
    Michigan
    I thought the same thing. That sensor appears to be bone dry =/
  20. #20 Re: Oil leak
    when running you will see it drip or pour out the plug end like your putting syrup on your waffles. i almost lost my engine because of that pos.
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
