Thread: Oil leak
Page 11 of 11 FirstFirst ... 91011
Results 201 to 218 of 218
  1. #201 Re: Oil leak
    back in the day its what you did to fix a pump, parts stores all sold just the pump, not any more, they sell you the whole canister these days. but on line they are available.
    im all about saving a 100 bucks when its within reach. and try to pass it on to you diy'ers. hell that 100 plus can be used else where better right?
  2. #202 Re: Oil leak
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    ^right. That $100 could be used somewhere else. I wish they still just sold the pumps too.. Sucks that they don't. Would it be a bad idea to see if a JY would have just the pump for a 99GTP?
    Or I found this
    http://www.discountbodyparts.com/cat...&Ns=price3%7C0
    Sent from my SM-N900P using Tapatalk
  3. #203 Re: Oil leak
    cheap is just that cheap lol not in my car it dont go lol.
    keep searching around, they are cheaper for a name brand part. http://www.ebay.com/itm/1998-2000-PO...-/170884902318 but this is all you need. just the pump.
  4. #204 Re: Oil leak
    TREperformance.com
    Pump only
  5. #205 Re: Oil leak
    http://m.ebay.com/itm/171350915557
    Make sure that I linked you to the correct one
    04 Comp G.
  6. #206 Re: Oil leak
    Aug 2011
    Michigan
    Looks right
  7. #207 Re: Oil leak
    Aug 2011
    Michigan
    The one I linked, is there a problem with it? I am wondering because my sending unit acts up. It says I have a full tank until I drive about 50+ miles. Then it slowly drops as I drive to about half a tank. After that it kinda plumets to a quarter amd then to E. I mean when it says I'm on E it's usually relatively accurate, I have a few gallons left. Thats why I am wondering if it would be worth it to replace the whole thing or not
  8. #208 Re: Oil leak
    yeah..you need the whole enchilada
  9. #209 Re: Oil leak
    Quote Originally Posted by tomtom123 View Post
    you can also get the dorman fix for that level sender for 20 bucks. and fix your canister 100%.
    http://www.ebay.com/itm/NEW-FUEL-LEV...119a2e&vxp=mtr
    double check this part for your car, it says all, so it should fit. 15 bucks is a win, free shipping too.
  10. #210 Re: Oil leak
    And I would rather have ac delco components then just some who knows remanuf.
    04 Comp G.
  11. #211 Re: Oil leak
    Aug 2011
    Michigan
    Alright guys thanks!
  12. #212 Re: Oil leak
    Aug 2011
    Michigan
    Scott, the description for that sender said 01 - 03 GTP mine is a 99 =/
  13. #213 Re: Oil leak
    i thought it said 97 up. but you can see they are out there and for cheaper still then buying a whole new canister.
    you maybe able to get the dorman one off advance auto's web site. buy on line pick it up. use a code for a few bucks off.
  14. #214 Re: Oil leak
    Aug 2011
    Michigan
    Fuel pump was the problem! Car is back on the road =]
    THANK YOU! Everyone for your help and advice. And infinite knowledge!!
  15. #215 Oil leak
    Woooooot
    04 Comp G.
  16. #216 Re: Oil leak
    Aug 2011
    Michigan
    Now I have to drive it a while to let it get its shifting figured back out. Likes to lag when shifting right now =P
    Hasn't had to shift in like 5 months almost! Lol
  17. #217 Re: Oil leak
    Feb 2013
    37.295091, -121.930053
    just take it easy on ye old pedal
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  18. #218 Re: Oil leak
    Aug 2011
    Michigan
    Haha yeah. Going to have to for a while =P
    Especially until the insurance is back on and my bank is off E ;P
  1. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  2. One Solution for Sunroof Leak Issue, leak through Dome Light
    By dmont in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2012, 10:14 PM
  3. vac leak, O2 code, exhaust leak.
    By al2000gtp in forum General Tech Discussion
    Last Post: 07-02-2012, 03:46 PM
  4. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  5. Is it safe to drive with an Header exhaust leak or any exhaust leak??
    By GOTIT4CHEAP16 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-11-2011, 05:45 PM
