Thread: 2004 GTP Lost performance
Results 1 to 14 of 14
  1. #1 2004 GTP Lost performance
    Jan 2014
    United States
    Hello all,
    I recently had a catalytic converter melt in my car and I removed it, drilled out, and cleaned it. Then I had the holes welded back up and bolted it back into the system. I replaced my gaskets but there was an upstream leak, and now it's pretty much open exhaust, and has been for the past month. Ever since it got clogged I've noticed lost performance, but now I really have been able to tell it lost all low end torque and just seems a tad slower even in high end rpms. Of course I have seen the code come up for o2 sensor misread, so I'm surely in open loop mode, but I am growing concerned that in the past 2 months I burnt my exhaust valves. What do you guys think? Could it just be due to loss of back pressure? Or are my valves burnt? Only other issue I've noticed is that when I am just idling it misfires and Sometimes it shifts a little weird.
    Lastly, when I come to a stop, a lot of times I can feel the transmission disengaging around 5mph, and whenever I'm driving at a steady speed, and then I let off the gas immediately, the rpm actually goes higher for a split second before going down. Is that weird?
    Sent from my SGH-M919 using Tapatalk
  2. #2 Re: 2004 GTP Lost performance
    if you have a huge exhaust leak right off the manifolds somewhere you gonna feel a hp loss. get that fixed. its maybe the cause of the o2 code.
    the tranny is fine, thats the tc unlocking.
  3. #3 Re: 2004 GTP Lost performance
    Jan 2014
    United States
    Thanks, and yeah the code is being thrown because I basically have no cat now lol.
  4. #4 Re: 2004 GTP Lost performance
    in that case fix the leak. and try the fouler trick for the rear o2. it moves the o2 out of the exhaust pipe so it gets faked out some times.
  5. #5 Re: 2004 GTP Lost performance
    Jan 2014
    United States
    Okay. That's cool, I haven't thought of doing that!
  6. #6 Re: 2004 GTP Lost performance
    Burnt valve's huh, thats a new one. You'd only do that running an open head, and not from a leak at the manifold to downpipe area.
    A rear o2 code can cause problems like you are seeing, it has a cat test and will engage it often with seeing no cat and will reduce fuel mileage aswell.
    Clean the throttle body and MAF sensor aswell, it can affect how the transmission runs.
  7. #7 Re: 2004 GTP Lost performance
    Jan 2014
    United States
    Okay guys I cleaned my maf sensor and tb the other day, ever since then my car can't idle and a steady rpm only while driving. Obviously something is wrong with the maf, I just wondered if there's something I can do to fix it without replacing it. I resprayed it to clean it today and it got a little better but the problem persists. Also, when I shift into drive and start accelerating lately immediately after starting car, the car shakes heavily and scares the **** out of me. So now I wait a full 1 or 2 seconds to start accelerating. What should I do?
  8. #8 Re: 2004 GTP Lost performance
    Aug 2013
    McDonald PA
    What did you clean the maf with
  9. #9 Re: 2004 GTP Lost performance
    Jan 2014
    United States
    Maf cleaner
  10. #10 Re: 2004 GTP Lost performance
    Aug 2013
    McDonald PA
    Quote Originally Posted by nickolaughagus View Post
    Maf cleaner
    Did you unplug it completely when you cleaned it
  11. #11 Re: 2004 GTP Lost performance
    Jan 2014
    United States
    No I couldn't unplug it lol I done effed up didn't i
  12. #12 Re: 2004 GTP Lost performance
    Aug 2013
    McDonald PA
    [Q UOTE=nickolaughagus;1233055]No I couldn't unplug it lol I done effed up didn't i
    Sent from my SGH-M919 using Tapatalk[/QUOTE]
    Possibly lol it could have still had power and fried cause I know every maf cleaner I've seen says to unplug the sensor and let it sit for a few to make sure it has no power to it
  13. #13 Re: 2004 GTP Lost performance
    Jan 2014
    United States
    I guess I'll go get a junkyard replacement. As for the shuddering, online it says that my clutch piston is going out. Is there any way that I can fix it?
  14. #14 Re: 2004 GTP Lost performance
    Dec 2010
    DMV
    Clutch piston?
    Sent from my HTC One using Tapatalk
  1. 2004 grand prix gt2 performance ideas
    By flyin hawaiian in forum General Grand Prix Discussion
    Last Post: 03-19-2014, 01:11 PM
  2. Lost modding interest ... Performance parts for sale !!:)
    By 97gtpjoe in forum For Sale - Parts
    Last Post: 08-08-2013, 01:31 PM
  3. Hello.. 2004 GTP Q's Brakes, HUD, Performance upgrades
    By Geeride in forum Introductions/Noob Questions
    Last Post: 02-05-2013, 01:07 PM
