Thread: Knock Sensor - Severed From Harness
Results 1 to 5 of 5
  1. #1 Knock Sensor - Severed From Harness
    Apr 2014
    Maplewood
    I have posted many times over the past hour or so, I know - but they are all different topics related to the engine, so I put them in separate posts.
    While rebuilding my engine, I discovered that one of the knock sensors was severed from the harness. Are these sensors vital to performance (does the PCM need them to run), or are they simply to measure knock?
  2. #2 Re: Knock Sensor - Severed From Harness
    St. Louis
    You need to wire that back up. Def. needed. If you remove the sensor from the block to repair this issue, the sensors need to be torqued to 14ft/lb upon reinstall.
  3. #3 Re: Knock Sensor - Severed From Harness
    X2 ^^^^^
  4. #4 Re: Knock Sensor - Severed From Harness
    You can replace just the little harness that runs up to the sensor if that's what's broken. Easy peasy.
  5. #5 Re: Knock Sensor - Severed From Harness
    For those of us with spares in a drawer!
  1. Knock Sensor ???
    By dbextreme in forum General Tech Discussion
    Last Post: 03-18-2013, 10:49 AM
  2. Replies: 3
    Last Post: 01-06-2013, 10:53 PM
  3. Knock sensor ?
    By kevins in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-23-2012, 05:54 AM
  4. knock sensor
    By redynscire in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-02-2011, 11:02 AM
  5. Knock Sensor
    By SuperCharged6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2009, 01:51 PM
