Wanted to know is it possible to drop to a 3.0 on stock Injectors? Gettin a 3.0 pulley and wanted to is it possible?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Doubtful. Usually below a 3.4 range you'll start maxing out your injectors. So it's time to spend some money on a set.
Yeah throw some 60s in there and corn feed that sum *****.
I pushed to 3.1 but when tuned I was running out of fuel at 5000 rpm. I went back to a 3.2.
Injectors and tune first screw 42s esp if your going to do e85 at least 60#ers Injectors tune pulley. Pulley size is only half the story if the timing sucks and knocks.........
I ran stock injectors on an XP cam setup GenV with a 3.2 pulley made 299whp. Injectors were at ~95% at 6100rpm.
Ran the 3.0 and 3.1 pulleys but the setup didn't like em, wasn't running out of fuel though.
