Thread: Losing boost at higher speeds
Results 1 to 5 of 5
  1. #1 Losing boost at higher speeds
    Aug 2012
    Danville
    Something I don't notice that often because I don't often go this fast, but when doing wot, when it gets up to 90mph, my boost drops off and the engine sounds quieter. My boost gage drops to about 1/3 to half and the engine seems to lose the growl and a little power, but it still accelerates. It seems to only happen at around 90+mph. Anybody ever experience this?
  2. #2 Re: Losing boost at higher speeds
    May 2014
    Starr, SC
    This happening on a 99 GTP?
    I would scan parameters on a normal drive and while doing pulls.
  3. #3 Re: Losing boost at higher speeds
    Apr 2011
    Vassar, Mi
    Its possible that it is going into cat protection. When I first got my car done it would lay over around 115 and lose boost. Turned the catalyst over temp protection setting off and it cleared right up.
    1999 GTP Coupe ------ Comp Cam 76-802-9, 2.7" pulley, S2IC, N*, FWI, SD Headers, DHP Tune, Built trans (single 3.29s, 300m), Magnaflow Catback, 60#injectors, E85, MT ET Street DR's, Fbody brakes, PRJ pump/rails. 302whp/328ft-lbs.......12.41@110mph
  4. #4 Re: Losing boost at higher speeds
    Aug 2012
    Danville
    Yes, this is a 99 GTP. I have a ECU with dsmuts program and don't know if it's going into cat protection. I didn't even know it had that feature.
  5. #5 Re: Losing boost at higher speeds
    Apr 2011
    Vassar, Mi
    Quote Originally Posted by 99GTPMLA View Post
    Me either I found out the hard way. In the supercharger table there is a box called "cat over temp boost reduction" or something to that effect. Once certain conditions are met while holding it wide open it commands the boost bypass solenoid to open. I had to go in on mine and turn it off
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. Higher wattage amp?
    By mick777wauchope in forum Audio, Security & Visual Electronics
    Last Post: 06-20-2013, 03:13 PM
  3. high compression, low boost. lower compression, higher boost
    By BlackGT97 in forum General Tech Discussion
    Last Post: 08-25-2011, 11:52 AM
  4. Boost lost at high speeds. Help?
    By pizzi22 in forum General Tech Discussion
    Last Post: 11-06-2009, 11:28 AM
  5. GTP with misfire at higher rpms or when boost starts to kick in
    By 00obgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-14-2009, 05:27 PM
