Thread: total cam install cost.
Results 1 to 13 of 13
  1. #1 total cam install cost.
    SE Level Member InsaneGTP's Avatar
    Jan 2013
    largo
    I tried looking for the answer and found minimal answers other then what Zzp reccomends on the checkout screen. Can anyone give me a list of things I would need to safely install a vs or xp cam? Also which would be more beneficial for the cost I have all of the other support mods for the cam I just want to make sure I have everything considered in the cost of it.
  2. #2 Re: total cam install cost.
    you need to take the front cover off as well as down to the heads on the block. so every gasket from the LIM up and the front cover gasket.
    you'll be urged to also replace wear items at the time (timing chain/tensioner, lifters, valve springs/retainers) of install to make sure you don't have to tear it down again anytime soon.
  3. #3 Re: total cam install cost.
    An xp package just sold on here for around 1k and looked to be about the closest "complete" kit ive ever seen. So thats a good estimate imo.
  4. #4 Re: total cam install cost.
    Yeah just buy one of the zzp cam install kits that comes with the timing chain and tensioner, some Crow Cams 105# lbs springs some OE-R Lifters and Manley Valve Retainers, if you have the cash go for the titanium ones, and you should be good to go. I am pretty sure I'm forgetting something though.
    -edit - Valve seals.
  5. #5 Re: total cam install cost.
    skip the OE-R lifters, get a new stock set instead. save money and not have a louder valvetrain.
  6. #6 Re: total cam install cost.
    GT Level Member WolvesSoulZ's Avatar
    Québec
    All included for my cam was 1841$, includes all oil, coolant, filters, brake cleaners, paint, gaskets, lifters, springs, retainers, cam, chain/dampner, pcm tune too.
    Difference is I had a blown headgasket and ticking lifters, burnt exhaust valves on cyl 3 and 5. Headwork was 400$ and I had a 300$ in time for the lift/garage and a bit of help. So remove 700$ and it was down to about 1141$, take in note that there are heavier shipping fees due to me being located in Canada.
    2000 GT - L67 swapped SOLD | 2004 GT1 - Winter Beater - SOLD
    2004 GTP Comp-G - 3.3"/3.2", XP, #50 , 4" MAF, SD's, 180*, AL103's, HAI, Tuned, 06+ Dual pistons brakes, STB's, SSC's and FE3.
    2011 Audi A6 S-Line - Also Supercharged
  7. #7 Re: total cam install cost.
    Jan 2013
    largo
    Thanks for the info
  8. #8 Re: total cam install cost.
    May 2014
    WolvesSoulZ sorry to butt in here, but what did you use to do your tail lights like that? looks awesome
  9. #9 Re: total cam install cost.
    Kemmerer, Wyoming
    has anyone else noticed the absence of the standard "XP" cam from ZZP's website?
  10. #10 Re: total cam install cost.
    Nov 2011
    NY
    You can order any grind direct from comp cams... Just sayin...
  11. #11 Re: total cam install cost.
    Quote Originally Posted by johntremell View Post
    You mean the XP hot cam pretty sure that's the same thing correct me if I'm wrong
    04 Comp G.
  12. #12 Re: total cam install cost.
    Kemmerer, Wyoming
    ^that is exactly what I am wondering^
    is this an xp hot cam?
    http://www.grandprixforums.net/threa...setup-for-sale
  13. #13 Re: total cam install cost.
    Sure is.
    04 Comp G.
  1. Grand Total for Headers
    By Ahaas96 in forum Introductions/Noob Questions
    Last Post: 11-16-2013, 08:20 PM
  2. Engine install cost
    By rotti3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-14-2011, 10:30 AM
  3. total radio conversion
    By Kenney2002 in forum Audio, Security & Visual Electronics
    Last Post: 07-23-2010, 09:41 PM
  4. FWI installed!! Total cost = $35
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 03-20-2010, 01:44 AM
  5. Total lift after rocker install.Question
    By TDCRacing in forum General Tech Discussion
    Last Post: 12-06-2008, 04:03 PM
