Its probably boost stacking.
Found out that the boost gauge wasnt properly hooked to the vaccum line by the map it was barely about to come off the fittings... lol.. problem fixed all by myself
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Very salty indeed no need to take it out on us we didn't hook your gauges up![]()
Having the same issue, but mine is stalling out randomly. It will start back up immediately, but just found that my bbv is also broken.
Making a hissing sound when i move the top around. Guessin that they may be the cause also of the vac leak im experiencing. LTFT's
are around 16.4 @ idle. STFT's are 20.3. So, when i replace it should stop the random stall?
It's a start.
Obviously if the bbv is broken.. Fix that first then if the stalking continues we go from there.. And yea that would explain one reason why the Ltft are being maxed out.
