Thread: bad map sensor?
Results 1 to 19 of 19
  1. #1 Re: bad map sensor?
    Jul 2008
    sumter,south carolina
    Restriction in air flow, or maybe a vacuum line that isnt quite 100% connected well are my best guesses at this point.
    Ok so i looked around under the hood and didnt see any loose or disconnected vaccuum lines.Do you happen to have one of those nifty diagrams for vac, lines?As for air flow restriction,where should i start looking?When you say that,all i can think of is from intake to the throttle body.Thanks in advance.
    02 GTP with mods 05 GP for DD
  2. #2 Re: bad map sensor?
    Oklahoma
    Well thats kinda what I had in mind really. I dont have any vacuum line diagrams at the moment but if I think about it I'll see what I can dig up.
  1. Is it possible to run without an O2 sensor?
    By Andrew_99GTP in forum PCM Tuning
    Last Post: 06-19-2008, 11:45 AM
  2. L67 MAF Sensor
    By J_Man55 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2008, 06:00 PM
  3. MAF Sensor
    Last Post: 06-13-2008, 02:57 AM
