Thread: Losing Coolant
Results 1 to 4 of 4
  1. #1 Losing Coolant
    May 2014
    Arizona (AZ)
    So I pour the coolant into the radiator and it pours out from under the engine. Any thoughts?
  2. #2 Re: Losing Coolant
    Have you checked the lower radiator hose
    04 Comp G.
  3. #3 Re: Losing Coolant
    Dec 2012
    Where 4T65E's were born
    Either that ^ or a popped freeze plug. Could be others, but those are the two lowest points it could leak.
    Sold.
  4. #4 Re: Losing Coolant
    get the car up on some car ramps or jack stands, and get under and look. most likely a freeze out plug popped out, or rusted out.
    if it is one of these plugs and its on the fire wall side the engine has to come out to change it. or the tranny, one or the other.
    one guy was lucky enough to get the rusted plug out, then installed a block heater to replace the freeze plug.
  1. 2001 GP SE 3.1 slowly Losing Coolant - From Where?
    By AJ1G in forum General Tech Discussion
    Last Post: 03-16-2015, 07:58 PM
  2. grand Prix losing coolant while off
    By Noure in forum General Grand Prix Discussion
    Last Post: 04-08-2013, 12:25 PM
  3. Losing coolant but no leaks?!?!?
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 12-20-2012, 09:08 PM
  4. '00 GT Losing oil and coolant + overheating
    By famous556 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-21-2012, 02:16 AM
  5. Losing coolant
    By MyPrixGT06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-17-2011, 07:18 AM
