Thread: Lead additive/octane boost/curtail KR??
Results 1 to 12 of 12
  1. #1 Re: Lead additive/octane boost/curtail KR??
    Oct 2011
    Toledo, OH
    Well you can increase octane to control KR without nasty lead additives by adding other high octane petroleum distillates such as Toluene (114 octane) or Xylene (116.5) to your fuel.
    Don't know about the 1997 specifically, but since it is ODBII it should be able to advance (or is it retard?) your timing to accommodate the different octanes. Routinely added a gallon of Toluene (free from work) to 9 gal of 93 octane gas in my 2001 3800 Firebird and it lasted 170k with no problems before a LIM failure did it in.
    7"
  2. #2 Re: Lead additive/octane boost/curtail KR??
    SE Level Member 1963SS's Avatar
    Apr 2014
    Eastern Kentucky
    Commercial octane boosters are a rip-off. Most will say "Raise your octane 3 points" or something like that. They are implying that your octane will increase from 91 to 94. 3 points right? Not so. A point is .1 so three points is 91.3 octane. Hardly worth the price in my opinion. Keep away from lead but you can make your own real cheap and get some real use out of it. Here are a few recipes that I've copied over the years.
    Keep in mind that more is not always better. You'll just want enough octane booster to stop your KR. Any more than that could hurt performance. There's not as much energy in 94 octane gas as there is in 89 octane. Typically all higher octane gas does is slow down the combustion rate. That's why it's probably best to run what the manufacturer says to run.
    Good Luck
    Toulene
    R+M/2...114
    Cost...$2.50/gal
    Mixtures with 92 Octane Premium
    10%...94.2 Octane
    20%...96.4 Octane
    30%...98.6 Octane
    Notes: Common ingredient in Octane Boosters in a can. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Often costs $3-5 for 12-16 ounces, when it can be purchased for less than $3/gal at chemical supply houses or paint stores.
    FORMULA 2
    Xylene
    R+M/2...117
    Cost...$2.75/gal
    10%...94.5 Octane
    20%...97.0 Octane
    30%...99.5 Octane
    Notes: Similar to Toulene. 12-16 ounces will only raise octane 2-3 *points*, I.e. from 92 to 92.3. Usually mixed with Toulene and advertised as *race formula*.
    MAKE YOUR OWN OCTANE BOOST How to make your own octane booster (this is the basic formula of one of the popular octane booster products). To make eight 16 ounce bottles (128 oz = 1 gal):
    100 oz of toulene for octane boost
    25 oz of mineral spirits (cleaning agent)
    3 oz of transmission fluid (lubricating agent)
    This product is advertised as "octane booster with cleaning agent *and* lubricating agent!". Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
  3. #3 Re: Lead additive/octane boost/curtail KR??
    Oct 2011
    Toledo, OH
    Quote Originally Posted by 1963SS View Post
    Not exactly true. Higher octane retards combustion, allowing more compression, which in turn delivers MORE energy upon release (ignition).
    "Premium" gas in the US is defined as 91 octane, yet the majority of the gas stations in the Mid-Eastern states carry 93, some even 94. While there IS a limit how much octane you can use before you see a decrease in performance, unless you are putting in straight toluene or something you probably won't reach that maximum in a modern vehicle.
    Exceptions exist obviously. Case in point, my 2007 Ninja has carburetors, with a 2 stage, RPM based timing. Putting in anything other than 86-87 octane makes it run like crap, because it doesn't have anyway to adjust for the higher octane.
    7"
  1. Engine Additive - Xado
    By 2003stivGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-15-2012, 07:50 PM
  2. reg gas and octane additive
    By lanz in forum General Tech Discussion
    Last Post: 04-25-2012, 11:03 AM
  3. Engine Flush Additive. Yay or Nay
    By midrange in forum General Tech Discussion
    Last Post: 02-13-2012, 11:07 AM
  4. lead...
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2011, 06:58 PM
  5. Gasoline Additive
    Last Post: 12-01-2008, 12:02 AM
