Thread: Supporting mods for cam?
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 94
  1. #61 Re: Supporting mods for cam?
    Mar 2012
    South Beloit, IL
    Gotcha. I am assuming you're ICed. As a forecast of what's to come for my car, approx. how much are you making on your vs cam setup?
  2. #62 Re: Supporting mods for cam?
    Not IC yet but will be in the distant future. Em my buttdyno says I'm making at least 1000hp lol.
    04 Comp G.
  3. #63 Re: Supporting mods for cam?
    Mar 2012
    South Beloit, IL
    Not fair. I haven't put my spoiler, stickers, and ground effects on my car yet! I'm hoping to be around 800 after that. I heard the ZZPerformance decal adds 500hp alone w/o a tune.
    I'm trying to decide whether to go e85 or IC.. or Both. lol
  4. #64 Re: Supporting mods for cam?
    Both lol but then u better be putting money aside for a transmission
    04 Comp G.
  5. #65 Re: Supporting mods for cam?
    Mar 2012
    South Beloit, IL
    Oh yeah, that's already been determined. Either that, or scrap the GP and buy this
    http://www.cars.com/go/search/detail...nal&listType=3
    Holy huge link.
  6. #66 Re: Supporting mods for cam?
    Buying someone else's project... big no no
    04 Comp G.
  7. #67 Re: Supporting mods for cam?
    Mar 2012
    South Beloit, IL
    But it's so shiny and looks well taken care of! Procharged! Roots style > Centrifugal anyday though
    If GTOs didn't cost so damn much, I would look into one of those.
    If only the GP was designed with the GNX in mind.
  8. #68 Re: Supporting mods for cam?
    Jan 2013
    Australia
    dont bother with the VS or S1X cams... go straight to the biggest cam for stock heads which is the XP. If its tuned properly you will not lose any bottom end torque.
    You will regret not having gone a bigger cam if you put the VS in... trust me. I even wish I'd gone bigger than XP and got headwork done etc...
    When I got my XP cam done and tuned it idles like a stocker and to be honest if someone would have come into my garage and secretly done it overnight without my knowledge I wouldnt even have noticed it... until I step on it and go over 3500rpm that is
    So basically drivability is exactly the same only with much more mid- and top end power than before... (I had 1.98 modded rockers on before)
  9. #69 Re: Supporting mods for cam?
    SE Level Member Daven's Avatar
    Apr 2014
    Saskatchewan, Canada
    Why e-85 anyways? Isn't that just "better for the environment"?
    And so the XP side finally speaks up. Quite the decision for me lol
    Using Tapatalk
  10. #70 Re: Supporting mods for cam?
    Mar 2012
    NC
    Quote Originally Posted by Daven View Post
    E85 is basically the poor man's race fuel. It doesn't like to burn just like 104 octane which gives the ability to run more boost/timing without detonation.
  11. #71 Re: Supporting mods for cam?
    Apr 2014
    Hmm weird. I probably wouldn't have a pump in my small city
    Using Tapatalk
  12. #72 Re: Supporting mods for cam?
    Mar 2012
    NC
    Yeah, it's only ideal for those with easy access.
  13. #73 Re: Supporting mods for cam?
    Aug 2013
    McDonald PA
    You'd be surprised where you can find it. But it's more available in the midwest
  14. #74 Re: Supporting mods for cam?
    Apr 2014
    Here's another scenario to keep in mind... I haven't looked around yet to see if there is a dyno tuner around me, but I'm thinking probably not. So it looks like I would be going the hptuner route. Obviously I have a lot of reading up to do yet on how to correctly tune it myself. But I just don't trust getting a company to make me a tune to work with my car reliably considering the variance in each car and the weather I see up here. And a dyno might not be much different. Winter here is VERY different compared to down south where you guys are lol I want to know my car won't knock like crazy when I reach those temps.
    So for the cams, and considering I have never messed around with tuning before, should I stick away from anything particularly tricky to get right?
    Using Tapatalk
  15. #75 Re: Supporting mods for cam?
    Well you have Will at Overkill he's somewhere In Canada and really you shouldn't be to worried mail order PCM work fine for most everybody just get one from a we known company.. When it comes winter time you can just pulley up.
    04 Comp G.
  16. #76 Re: Supporting mods for cam?
    Apr 2014
    Can you just simply swap pullies to a larger one when the air gets colder, without messing with the tune and causing problems?
    Using Tapatalk
  17. #77 Re: Supporting mods for cam?
    Yup.. Most of the time guys do the opposite the cold air allows you to pulley down for the most part and kills any KR that you may of had during the warmer months.
    04 Comp G.
  18. #78 Re: Supporting mods for cam?
    Apr 2014
    I thought the denser air causes more boost which in turn is like using a smaller pully? Causing more knock?
    Using Tapatalk
  19. #79 Re: Supporting mods for cam?
    Yes.. But also allows some guys to pulley down more then others. KR is always I concern but that's why you'll have something to scan with just in case. You can always pulley up durning the winter it won't hurt anything because let's face it when winter hits I bet the last thing your going to want to do is to make wot runs. Most of the time you'll probably be driven it conservative and dreaming about those summer months.
    04 Comp G.
  20. #80 Re: Supporting mods for cam?
    Mar 2012
    South Beloit, IL
    Daven this should be able to answer your question about what cam to get. From what speed do you want to race? If it's from a dig or 30 to around highway speeds, the VS cam is superior. The XP takes the cake on the highway and higher RPMs.
  1. What supporting valvetrain mods for cam?
    By Brooks in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-23-2010, 11:54 PM
  2. What supporting mods to run a NIC cam??
    By 16MustangVet in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2010, 06:56 AM
  3. Supporting Mods.
    By zildjian102 in forum General Tech Discussion
    Last Post: 06-16-2010, 03:05 PM
  4. supporting mods?
    By riceburner in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-15-2008, 01:01 AM
