Thread: Fuel Injector #1 Squirting Gas
Results 1 to 4 of 4
  1. #1 Fuel Injector #1 Squirting Gas
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    03 gtp, 142k mi.
    I changed my fuel injector o-rings w/ fel-pro, mainly b/c I need to change my valve cover gaskets. When I finished tightening everything down, I re-installed gas cap, fuel pump fuse, & negative battery cable. Turn ignition to ON, & gas shoots out of top of injector #1 where it enters the rail. Shoots like a drinking fountain with your thumb over it.
    What did I break?
    Advice. is greatly appreciated. Thanks.
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  2. #2 Re: Fuel Injector #1 Squirting Gas
    pop the rail and injectors back out, the o ring is out of place i bet.
    you want to lube the o rings with some oil then slide then in the holes.
  3. #3 Re: Fuel Injector #1 Squirting Gas
    Nov 2011
    Chicago
    All the repair instructions say to buy extra o-rings, so I did & it's a good thing. The top injector o-ring had a good nick in it so it was just spitting gas onto engine.
    Thanks Scotty!
  4. #4 Re: Fuel Injector #1 Squirting Gas
    nice find.
  1. How do you unplug a fuel injector?
    By Sudden in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2013, 06:03 AM
  2. Fuel injector help !!!!
    By GTPAIELLO in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-06-2012, 06:48 AM
  3. fuel injector resistance
    By Viprklr in forum 5.3L V8 (LS4)
    Last Post: 06-17-2012, 11:48 AM
  4. prj fuel rainl/ injector help
    By Taz Magister in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-14-2012, 02:55 PM
  5. Fuel injector seating
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-29-2010, 10:42 AM
